Vacuum leak?.....
Old June 6th, 2009, 06:23 PM   #1
1986 mustang gt
1fst5.0 is on a distinguished road
Vacuum leak?.....
Whats up fellas, i need ur guys help again.I recently had to remove my upper and lower intake. when i was putting it all back, i layed a thick bead of gasketmaker on the front and rear of the block, then i layed the lower intake on. After i was done with the job, i could hear a small vacuum leak, but couldnt find it, even with carb cleaner. i could tell it was around the PCV area. and now theres a puddle of oil leaking at the rear of the block were it meets the intake. Do u guys think thats where my vacuum leak is and is that leak enough to make my car idle like crap?
Old June 6th, 2009, 09:53 PM   #2
The Razor's Edge
White Thunder's Avatar
yeah thats why idel sucks....you cant see where the oil is coming.....get you some fel pro gaskets
founder of the FTN Club
Old June 7th, 2009, 12:08 AM   #3
1986 mustang gt
what kind of RTV should i use? i just took it apart and the gasketmaker didnt bond with the lower intake, just the block. i used some grey RTV this last time.
Old June 7th, 2009, 12:38 AM   #4
1998 Cobra
13.24@105.66
intake valley seals suck...
weeee foooord!
Old June 7th, 2009, 07:37 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Yep, that is your vacuum leak. The pcv draws from the lifter valley. If you don't have a good seal there you will have a vacuum leak.
Old December 14th, 2009, 06:46 AM   #6
kaeo1981's Avatar
1991 MUSTANG GT
kaeo1981 is on a distinguished road
Send a message via Skype™ to kaeo1981
Not Sure If This Might Help B/c I Am New To Mustang Motor Building Myself, However, I Used Both Felpro Gaskets And Rtv Gasket Maker And It Sealed The Crap Out Of It. Give That A Shot. Seemed To Work Well For Me. If Anyone Thinks This May Be A Bad Deal Then Please Let Me Know. Like I Said, Im New To This Myself.
Old December 14th, 2009, 08:19 AM   #7
I use nothing but permatex gasket maker... thick bead around everything and have never had a problem with this except when I have to yank the lower for what ever reasons..
Old December 14th, 2009, 01:13 PM   #8
1992 Lx
11.39@119.24
can of the right stuff ftmfw
Old December 14th, 2009, 06:51 PM   #9
The Razor's Edge
lol this old ass thread....
Old December 28th, 2009, 07:19 AM   #10
kaeo1981's Avatar
1991 MUSTANG GT
Not sure if you got your leak fixed yet (hopefully you did), however, I agree with 1slo5.0, the pcv leak will def cause a major leak. thought mine was secure and when i took it for a test drive thru my neighborhood the damn thing blew out and oil was spurting all over my windshield (didn't have hood on). truth be told, it was freakin hilarious. not hard to fix tho. good luck....
Old December 28th, 2009, 10:32 PM   #11
87 MUSTANG GT
12.87@107
electricblue87 is on a distinguished road
Send a message via AIM to electricblue87
I Agree Most Likeley The Pcv Leaking.however There Is All Those Tiny Brittle Ass Mini Vacume Lines That Break Any Time You Breath On Them Too.that Can Also Cause Vacume Leakage
Threads Similar to: Vacuum leak?.....
Is It A Vacuum Leak? white03v6 V6 Mustangs 10 February 2nd, 2009 12:13 AM
vacuum leak JASonic V6 Mustangs 17 January 19th, 2009 07:10 PM
possible vacuum leak? 02MiNeRaLgRaYGT 99-04 6 September 24th, 2008 01:27 PM
96 Gt With A Vacuum Leak sorrowfulkiller Modular Mustangs 38 November 15th, 2007 02:17 AM
vacuum leak DragonFreak 96-98 1 July 11th, 2007 09:12 PM
