Which heads????
Old June 7th, 2009, 10:46 AM   #1
1990 Mustang GT
N/A
NOSfairlane is on a distinguished road
Which heads????
so i got this 5.0 roller motor outta a truck to put in my 1967 ford fairlane i am debating on which heads i should use these stock E6 heads which look like a smaller cc or my stock 289 heads? i need lots of low end torque to get this boat movin so any info on what heads i should use would be great
thanks Keefer
Old June 7th, 2009, 11:56 AM   #2
1986 mustang gt
1fst5.0 is on a distinguished road
arent the E6 the same as on the 1986 mustang? if they are, dont use them, at the very least, find some E7s.
Old June 7th, 2009, 12:02 PM   #3
Lind's Avatar
1994 Ford Mustang GT
Lind is on a distinguished road
any stock ford head doesnt flow for shit, if your looking to spend money then get yourself a decent set of used heads or cheap new 1s
www.moddedmustangs.com
Old June 7th, 2009, 12:14 PM   #4
BlessedHellride's Avatar
1988 Notchback
11.19 @ 122mph N/A
BlessedHellride will become famous soon enough
Get a set of heads from a Ford Explorer if you are on that much of a budget.
FluffyTheRhino:
One time, the tramp I was fornicating with farted, and I felt it blow my balls backwards.
1988 Notch 347 C4 w/brake 3.90 gear
11.19 @ 122mph 60' 1.67 N/A
Full Interiored pump gas car
Old June 7th, 2009, 01:03 PM   #5
The Razor's Edge
White Thunder's Avatar
if you already have the 289s throw em on there....
how much money you go laying around?
founder of the FTN Club
Old June 7th, 2009, 01:14 PM   #6
Holy Dick Castle!
dr.gonzo!'s Avatar
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
dr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant future
gt-40 's will work the gt-40p needs different headers like mac or the stock 5.0 headers will work. But im not sure they will work in a fairlane. you can check corral classifieds for some tfs heads.
Old June 7th, 2009, 01:59 PM   #7
86er's Avatar
stock mustang header should have no prob fitting in the whale mouth of a fairlane engine bay
Just a truck
Old June 7th, 2009, 07:36 PM   #8
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
thanks Keefer
If you want torque build a bigger engine. Cubic inches makes torque, not small runner cylinder heads.
Old June 9th, 2009, 09:55 AM   #9
1990 Mustang GT
N/A
i was looking at a 390 but i need to get a c6 with an FE bolt pattern.. i started porting my 289 heads so thanks for the info
Old June 9th, 2009, 10:12 AM   #10
Proud American
MustangMatt96GT's Avatar
Do not run the 289 heads... The exhaust ports are the size of my pinky...
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old June 9th, 2009, 10:34 AM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Porting is a science, not just grabbing a grinder and hogging some ports out. Good luck with that.
Threads Similar to: Which heads????
GT 40 X Heads. Need Help Deciding On These Heads, Or AFR`s BillR1970 Parts 8 May 12th, 2009 09:01 PM
351W heads vs gt40p heads? mustangsoldier 5.0 Mustangs 16 December 10th, 2008 11:00 PM
GT40 heads vs GTP heads 99TurboV6Stang 5.0 Mustangs 9 September 18th, 2007 09:34 PM
RHS heads , are they good cylinder heads? hitorx 5.0 Mustangs 25 May 12th, 2007 09:55 PM
Boss 302 Heads Same As Cleveland Heads? ken5_0 Classic Mustangs 8 September 25th, 2006 03:18 PM
