Factory o2's
Old June 7th, 2009, 10:22 PM   #1
Stangzilla's Avatar
Stangzilla is on a distinguished road
Factory o2's
before I break out the multimeter & start poking around does anyone know where the factory o2 sensors are grounded 2? R they grounded back at the computer or somewhere else? Also I know it's not to uncommon for there 2 B a grounding problem on 1 or both of the sensors.. Do they share a common ground? Thx all...
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old June 7th, 2009, 11:16 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
They are grounded to the firewall from the engine harness.
Old June 7th, 2009, 11:32 PM   #3
Stangzilla's Avatar
Do they share a common ground? On my PMS the left o2 is cycling properly stayin below 1 volt toggling rich-lean making corrections. My right 1 is from 2-3 volts.. Both sensors r brand new Bosch sensors. I will start with swapping the right & left plugs & see if it changes..
Old June 8th, 2009, 12:01 AM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Yes.
Give me a minute and I'll dig up some diagrams.
Old June 8th, 2009, 12:08 AM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Old June 8th, 2009, 12:12 AM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Old June 8th, 2009, 12:21 AM   #7
Stangzilla's Avatar
Wow!! Thanks alot!!
Old June 8th, 2009, 09:29 AM   #8
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Wow!! Thanks alot!!
No problem buddy!
Threads Similar to: Factory o2's
where can i get my rear o2's turned off?? o2gtstang 99-04 12 March 28th, 2009 02:12 PM
ques. about o2's armymike63b 4V / SVT 14 July 29th, 2008 02:39 PM
Rear O2's injected03stang 99-04 16 June 6th, 2008 01:03 PM
Turn off rear o2's 90Stang 2005 - 2010 10 June 3rd, 2008 09:25 AM
