5.4 Swap In a 90 LX
Old June 8th, 2009, 12:16 AM   #1
OneBadNotch's Avatar
1990 lx
OneBadNotch is on a distinguished road
5.4 Swap In a 90 LX
I just recently came across a 5.4 2v at a price i couldnt turn down. I have seen numerous people doing the 5.4 swap in the newer models, but not many in older fox bodies. I have talked to a few people about it, and they say that it can be done and has been done before. So i decided to go for it, and do a 5.4 swap in my 1990 lx. The only problems that i am hearing about is how much harder it is to get the same amount of power out of the 5.4 2v as it would be to get it out of the 4v. And since the 4v can only be found in the lincoln navigator and blackwoods, the price is outrageous. What can i do to to help with the power in my 2v. Any suggestions on cams, intakes, etc.
Old June 8th, 2009, 12:22 AM   #2
86er's Avatar
86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold
go to a junk yard and buy a set of heads off of a lincoln mark 8. its the B head same head as on the 96-98 cobra. Can prob get them for 100 bucks tops well down here you can, buy the needed timing chain stuff and a cobra intake and you have a hell of a motor thats just itching for boost
Just a truck
Old June 8th, 2009, 12:23 AM   #3
86er's Avatar
when my 351 pops or if someone wants to buy it, im gonna go 5.4 4v rout with a nice turbo hanging off it
Just a truck
Old June 8th, 2009, 12:31 AM   #4
1990 lx
Yea, i wish i had the money to just buy a 4v, but i cant seem to come up with it right now. But down the road i was thinking about installing a lysholm 1.6 twinscrew on it. But i still think i might come up a little short on horsepower. Im shooting for about 650-700. Any other suggestions?
Old June 8th, 2009, 12:40 AM   #5
1998 Cobra
13.24@105.66
Pushrods engines are so much cheaper to make faster..
weeee foooord!
Old June 8th, 2009, 01:25 AM   #6
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
ok so you can swap 2v and 4v heads.....are all 4.6 blocks the same......can u just swap 2v heads with 4v heads on say a 2000 gt....i ges if you swapped heads you would have to swap the intake though....are the 5.4 and 4.6 blocks the same
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old June 8th, 2009, 01:29 AM   #7
aka Nature boy
sickfox's Avatar
blk 89/red 91 XJ Limited
I like turtles
sickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant future
thats gonna be sick when you do that, good luck!
Black Stang Crew Founder #-1
MM+Cleavage Club #15
www.xjor.org
I would drag my dick through a mile of broken glass just to hear her fart through a walkie talkie
Old June 8th, 2009, 01:37 AM   #8
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
5.4 and 4.6 blocks are different. Heads *may* interchange, but I'm almost positive the intake manifold is unique to the 5.4.
5.4s are difficult to get power from at anything resembling reasonable amounts of money, and I'd argue that you can get more from a stock-stroke 5.0 than you'll ever see out of a 2v 5.4L. There's just not the aftermarket for those motors like there is for the 5.0 or 4.6.
Props to you for doing it, but if your goal is making power, I think you're gonna be disappointed.
You'd probably get a lot more information posting this in the modular section.
O o
/¯/______________________
\_\
Buy my Bronco, special deal for MM folks
Old June 8th, 2009, 01:40 AM   #9
12.8@103... stock motor
11.8@113...150 shot
R0B0T can only hope to improve
if you're doing it because you're bored, or want something weird, go for it...
if you want a race car, don't waste the time.
Old June 8th, 2009, 06:19 PM   #10
86er's Avatar
factory 4v heads flow crazy, dont even need to port them. A set of cams albeit pricey are a nice investment, along with longtubes.
The heads are all the same 5.4 or 4.6, you can put any 2v or 4v to any motor.
Intakes are dif, just like a 302 to 351w. Just wider. They make a few intakes that are perf oriented. Just depends on how crazy you want.
The thing with mod motors, you can use factory ford stuff and build a short block that will handle 1200hp.
Buddy has a 5.4 4v with a 76mm makin 11xx on stock heads, cam and internals.
Just a truck
Old June 8th, 2009, 08:18 PM   #11
86er's Avatar
stock parts and a turbo kit and you can plush 1000hp all day long
ford even has 83lb/hr injectors now in mod motors.
dont see a stock parted pushrod doing that.
The parts arent that bad, is all where you go to buy them
Just a truck
Old June 8th, 2009, 08:20 PM   #12
86er's Avatar
go talk to Al Pappito and ask him about his all motor 5.4 thats puttin down almost 500 at the wheels.
using all stock parts, except cams I believe
You should do more searching before you speak of something you know nothing of.
the intake manifold and internals are the only real parts that are different.
thats only because of the longer stroke of the crank and longer rods.
Just a truck
Old June 8th, 2009, 08:59 PM   #13
Remember that I said 2v 5.4L. Al Papitto is using a 4v motor.
Here's an excerpt talking about Al's car, the whole article can be found here: 1997 Cobra Al Papitto - 5.0 Mustang & Super Fords Magazine
Al began cooking up a combination. He started by having the block bored 0.020 over and filling it with the stock forged crank, Manley billet rods, and custom JE pistons. American Cylinder Head handled the machine work, while Al sourced Pro Power for the rods and pistons.
With the bottom end transformed, Al set his sights on the Four-Valve heads-the most modified part of the engine. His motorcycle background made the modifications come easy. "The Four-Valve's tumble-port design looks a lot like a Suzuki Hayabusa head," he says.
Cope Racing Engines' (which built and prepared the engines for the late Dave Schultz's three-time championship Suzuki and Al's two-time championship Suzuki) Buddy Ordway spent many hours on the valve seats and ports, while Al was busy making the valves from Ferrea blanks initially designed for Kawasaki engines. Kawasaki Z1 valvesprings and titanium retainers, along with Crane Cams' reground cams, complete the valvetrain.
Though the heads were easy, the difficult part came in the intake department. After much research, Al decided to make his own lower intake, which took him a month and a $3,000 investment. A Hamilton Clarke intake cover tops it off.
Bolding done by me. So remind me what's stock in this motor again? Block and crank?
Right back at'cha, bub.
O o
\_\
Old June 8th, 2009, 09:24 PM   #14
jat
jat is on a distinguished road
Send a message via AIM to jat
just buy a ford racing aluminator(4v)and boost it. throw it in a fox and ur good.
Old June 8th, 2009, 10:58 PM   #15
86er's Avatar
power from a 2v 5.4 is not hard at all
id take a PI 5.4 2v and run it all day long against a bolt on 5.0.
I dont know too many intake, headers and exhaust 5.0's are runnin in the 12's.
I know of at least 15 99+gt's with just those mods on a PI 5.4 running 12.70's and quicker in a car thats heavier
Just a truck
Old June 8th, 2009, 11:14 PM   #16
What's a PI 5.4?
Do you mean a 5.4L that someone swapped 4.6L PI heads on?
O o
\_\
Old June 8th, 2009, 11:51 PM   #17
86er's Avatar
99 and up like the 4.6
Just a truck
Old June 9th, 2009, 12:01 AM   #18
Ah, k, didn't know the 5.4 got PI heads the same year as the Mustang.
O o
\_\
Old June 9th, 2009, 12:15 AM   #19
86er's Avatar
5.4 L V8 1997-98 235 hp (175 kW) 330 lb·ft (450 N·m)
5.4 L V8 1999-2004 260 hp (190 kW) 350 lb·ft (470 N·m
5.4 L V8 3V 2004-2008 300 hp (220 kW) 365 lb·ft (495 N·m)
5.4 L 3V 2009- 310 hp (230 kW) @ 5000 rpm 365 lb·ft (495 N·m)
5.4 L 3V (E85) 2009- 320 hp (240 kW) 390 lb·ft (530 N·m)
Just a truck
Old June 9th, 2009, 12:34 AM   #20
Yeah, I saw that chart on wikipedia, too, hahaha.
O o
\_\
Threads Similar to: 5.4 Swap In a 90 LX
Which one is easier??a rear end swap or engine swap? Bies08 V6 Mustangs 42 May 11th, 2010 05:33 PM
PI Head Swap and Transmission Swap jEEd 96-98 18 May 14th, 2009 01:57 AM
96 gt swap quartermile 96-98 2 January 5th, 2009 11:05 PM
1995 351 to swap or not to swap.& how to? Jeffery9508 94-95 9 August 3rd, 2008 09:00 AM
Can't decide, engine swap or PI swap? A few questions... k3vin 96-98 24 September 5th, 2007 07:48 PM
