1993 Mustang GT
Tach issues
So, I make a lot of threads, but that's because others don't always give me the best answers to my specific problem. ANYWAYS...
My tach doesn't work correctly. I turn the car on and the tach jumps to about 3,200 RPM's, and I know the car isn't idling that high, duh. Once you give it gas and it passes that point, it advances like normal. Now I know the stock tach is inaccurate, but I'd just like it to at least look like it works. Hot or cold start makes no difference, nor does driving vs idling, or when it shifts. It's AOD by the way if that makes any difference. |
The Razor's Edge
forget the stock tach they suck.....go aftermarket
#3 | |
1993 Mustang GT
Should I just try and pull it out of the cluster and mess around with it, or what?
1988 lx
13.13@101.78
don't waste your time. Autometer FTW
![]() 302 out of a lincoln lsc, Cobra upper and lower, 1.6 rr's, msd cap, bbk equal lengths, off road h pipe, mac pro chambers, 4:10's, bbk drag launch springs, 4cylinder tranny, short shifter, 20% tint, and 6k H.I.D's. 13.13@101mph 1.8 60ft on D/R's |
1993 Mustang GT
Okay, well I don't want an aftermarket one, I just want the one I have to work, like I said in the original post.
1991 mustang 5.0
Mine is off by like 200 rpms. Just get an aftermarket one
He doesn't want an aftermarket tach so quit trying to shove one down his throat.
To the original poster, I have never taken the cluster itself apart so I really don't know anything about the cluster itself. I have taken the entire cluster out and swapped them and that is fairly easy.
If the problem is in the cluster you will probably have to find and another cluster. The wiring mat (not sure of it's true name) is usually not serviceable. You should have no troulbe finding one in a part out.
89 LX Coupe: Factory 5.0, common performance and suspension bolt-ons (306 build inprogress) 86 GT: (current 1/4 project) will have primarily Team Z suspension and chassis additions, 408 with nitrous in the works
I have a couple clusters laying around if your car is a 1987 or 1988 Mustang.
#11 | |
1993 Mustang GT
You understand, haha.Yeah, my speedometer has the "hesitation wiggle" too, so I may just replace the whole thing, any suggestions/places to get the cluster from? Or install tips? |
I don't know where you can get a new one but used clusters are all over Ebay. I have a couple here depending on what year the car is.
1993 Mustang GT
It's a 93GT
Sorry, I don't have a cluster for that. You should be able to find something on Ebay.
The Razor's Edge
Threads Similar to: Tach issues
| tach install..... tach adapter | 02S281 | 99-04 | 8 | August 21st, 2008 01:35 PM |
| Autometer Tach/Tach Light and Ford racing Tach Driver install help | 94stang | 99-04 | 10 | April 18th, 2008 11:35 PM |
| New Tach | Pony_with_an_attitude | 5.0 Mustangs | 12 | February 28th, 2008 10:49 PM |
| tach | notsoslo5.0 | 5.0 Mustangs | 3 | January 3rd, 2007 08:20 PM |
