ls1 swap
Old June 8th, 2009, 01:13 AM   #1
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
ls1 swap
anyone know of any good writeups for an ls1 swap into a fox....or at least all the parts needed for the swap and would it be easy enuf to keep it fuel injected if u had the computer and wiring harness....
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old June 8th, 2009, 01:17 AM   #2
MSTRB8N & MDR8N
BWAL's Avatar
2021 Mustang V15
Quad Turbo with nawz
BWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond repute
good question, try posting this in the LS1 section of the forum.. oh wait..
MM 1 am boner crew
Cars and mod list in garage
i like veiny meat sliding between my buttcheeks
Old June 8th, 2009, 02:39 AM   #3
Genibus Nitito Canus
HBK_2007's Avatar
2009 Ford Mustang GT
HBK_2007 will become famous soon enough
Send a message via MSN to HBK_2007
head over to mafiamotorsports.com and look for a guy named "halfbreed" hes very knowledgeable about LS swaps into foxs
Red 1996 GT: JLT RAI, Steeda Underdrive pullies, Stewart Waterpump; nothing to brag about
Black 2009 45th aniverary edition GT 5 speed: K&N CAI, BBK Twin 62mm Throttle Body, BBK Underdrive Pullies, SLP Loudmouth
Old June 8th, 2009, 04:04 AM   #4
The Razor's Edge
White Thunder's Avatar
there are some on Chevy | Camaro | Firebird Reviews, Performance Parts, Modifications - LS1Tech.com
its going to cost up towards 10k for the swap....
founder of the FTN Club
Old June 8th, 2009, 07:13 AM   #5
1990 Mustang GT
i dont see how it could cost that much.....im seeing used engines and tranny combos going for aroudn 2k....give or take...and thats with the wiring harness and computer....then you would need a custom driveshaft and probly a cross member and kmember...i may be wrong but it seems like it could be done cheaper than 10k
the reason i was thinkin about this is because the ls1 really is a kick ass motor whether some of you want to admit it or not.....i figure i cud spend 2500 on a top end kit and another 1200 or so on a stroker kit and machine work for the block plus all the money for the supporting modds and maybe make 400 hp at the flywheel and not have much room to expand.....or could go with the ls1 and already have the 346 cubic inches and 350 hp bone stock.....down the road throw on a top end kit and make possibly 450 rwhp....and the stock bottom end and block can handle pretty decent power....i have heard at least 600 and most likely more.....and i will have an all aluminum setup....it just seems like it would be a good idea if i could pull it off
1990 GT
2004 Impala SS
2001 Tacoma
Old June 8th, 2009, 09:33 AM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Says who? I can't see how this swap would add up to anywhere near $10,000.
Old June 8th, 2009, 11:42 AM   #7
1990 Mustang GT
also if i bought one with a t56 would the shifter come through the console at the same place where my t5 does right now
1990 GT
2004 Impala SS
2001 Tacoma
Old June 8th, 2009, 12:11 PM   #8
88_FiveOh's Avatar
1988 lx
13.13@101.78
88_FiveOh is on a distinguished road
They sell a tubular k member with the motor mounts in the right spot for the ls1
302 out of a lincoln lsc, Cobra upper and lower, 1.6 rr's, msd cap, bbk equal lengths, off road h pipe, mac pro chambers, 4:10's, bbk drag launch springs, 4cylinder tranny, short shifter, 20% tint, and 6k H.I.D's. 13.13@101mph 1.8 60ft on D/R's
Old June 8th, 2009, 12:16 PM   #9
1992 Lx
11.39@119.24
Cool
yup exactly what i was gona say
Old June 8th, 2009, 01:15 PM   #10
HBK_2007's Avatar
well rather than invest all that on a 302, how bout u invest it in a 351 poked out to 408? then uve got even more power than either 302 or ls1 and its a direct bolt in
Old June 8th, 2009, 01:20 PM   #11
Atomized
gotn20's Avatar
gotn20 will become famous soon enough
what's up with the lsx's and piston slap? My brother and law has an ls1 gto well maintained and it has wicked piston slap at startup. Is this common?
spray and pray
Old June 8th, 2009, 01:40 PM   #12
88_FiveOh's Avatar
1988 lx
13.13@101.78
a newer gto?
Old June 8th, 2009, 03:20 PM   #13
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Common. The trucks and SUVs did it too. I don't think it is such a problem anymore. There is a TSB on it. Excessive piston to wall clearance. It doesn't cause any harm.
Old June 8th, 2009, 03:23 PM   #14
88_FiveOh's Avatar
1988 lx
13.13@101.78
not to thread jack but what do you need to just install the tranny?
Old June 8th, 2009, 05:16 PM   #15
Chris951's Avatar
1991 mustang 5.0
Chris951 is on a distinguished road
I heard it was how they are assembled. very common. My dad's 99 vette has it bad
Old June 8th, 2009, 10:13 PM   #16
1988 LX Procharged 347
Procharged 347 is on a distinguished road
yup, me too. here's my contribution to this thread
[SIGPIC][/SIGPIC]
[FONT="Arial Black"][SIZE="4"][COLOR="Red"]Procharged 347 stroker [/COLOR][/SIZE][/FONT]
Old June 8th, 2009, 10:30 PM   #17
The Razor's Edge
there was a guy on ls1tech who said he was 8k into the swap and still needed odds and ends. This included the roller and with a 6 speed
Old June 8th, 2009, 10:41 PM   #18
StarCity is on a distinguished road
...6.0 cast iron block and gto 6spd trans, and vette aluminum heads I think
Old June 8th, 2009, 10:54 PM   #19
aka Nature boy
sickfox's Avatar
blk 89/red 91 XJ Limited
I like turtles
sickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant future
i agree with going this route.
Black Stang Crew Founder #-1
MM+Cleavage Club #15
www.xjor.org
I would drag my dick through a mile of broken glass just to hear her fart through a walkie talkie
Old June 8th, 2009, 11:39 PM   #20
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Roller? Like the car?
Threads Similar to: ls1 swap
time for the LS1 swap brakl8r 99-04 45 March 13th, 2012 10:08 PM
4.6 or 5.0 or LS1 Haseeb718 The Clubhouse 114 November 4th, 2009 03:31 PM
LS1 zinc02GT The Clubhouse 20 March 14th, 2009 06:44 PM
The LS1 ByPopularDemand The Clubhouse 15 August 21st, 2008 06:38 PM
Ls1 DOWN Black02GT The Clubhouse 41 August 18th, 2008 08:02 PM
