Nitrous nozzle throttle body screwed
Old January 27th, 2007, 08:47 PM   #1
89Domindart's Avatar
89mustanglx5.0
89Domindart is on a distinguished road
Send a message via AIM to 89Domindart
I have a dry nitrous set up and the nozzle
..goes into the throttle body via a drilled hole. Its been kind of striped out a bit, both in the nozzle and the throttle body hole.
Does anyone know how to "tap" a new thread in something like this? I dont know anything about fixing this type of thing.
I was thinking maybe get a new nozzle and tap it somehow...?
thnx guys.
looking for a mustang again.!
Old January 27th, 2007, 08:56 PM   #2
JBIGBOOTSY's Avatar
1990 LX hatch
Find the right size helicoil
Old January 27th, 2007, 09:00 PM   #3
all motor
SALIV8's Avatar
92 coupe
9.94@136.40
SALIV8 is on a distinguished road
There's a tap and die kit you can buy, you size the tap for what you need, screw it in and it makes fresh theads, given there's enough metal there to do it. You unscrew it and you're done. Also they have all sorts of thread repair kits out there as well.
Old January 27th, 2007, 09:12 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The size of the nozzle is 1/16 npt.
Old January 27th, 2007, 11:45 PM   #5
Stangzilla's Avatar
Stangzilla is on a distinguished road
Chances are there will not be enough metal to clean up the thread with a tap. you might have to go with the helicoil route but i dont know if they make them in npt thread type....
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old January 28th, 2007, 12:06 AM   #6
5-0stank is on a distinguished road
u could weld it back up and redrill/tap
1995 GT::Sold!
Looking for another stang...
Old January 28th, 2007, 02:34 AM   #7
Stangzilla's Avatar
You have to be a really good welder to fill a hole in that thin aluminum without melting it. Remember its cast and very thin I dont think it will hold up to the heat... U have a better chance of filling it with JB weld or somthing similar then drilling and retapping it...
Old January 28th, 2007, 11:33 PM   #8
89mustanglx5.0
I thought about that but i dont know.... what is a helicoil? and npt thread type????
Old January 29th, 2007, 10:50 AM   #9
all motor
SALIV8's Avatar
92 coupe
9.94@136.40
Helicoil is a thread insert that looks like a spring, and npt is a thread type. It stands for 'National Pipe Thread' size. Is a standard size,like coarse thread, fine thread, machine thread, etc...
Old January 29th, 2007, 09:32 PM   #10
Ask All My Baby's Mommas
lineumup88's Avatar
lineumup88 is on a distinguished road
is this a stock throttle body. you should be able to find another one cheap. but if you are gonna go the jb weld route then you could drill and tap another hole in a different place, but smaller. that way you can put new threads on the nozzle and in a new hole
hey chevy boy.....i got something for you to POWERSTROKE!
Warning: surgeon general says its ok to smoke ricers!
Old January 29th, 2007, 09:39 PM   #11
Stangzilla's Avatar
thats true just fill the hole with JB weld or something and like he said just drill and tap the hole on another part of the throttle body...
Old January 29th, 2007, 10:08 PM   #12
nolife's Avatar
91GT, 88GT, 02GT
What about that "as seen on TV" Alumaloy stuff, it might actually work for this. I think I saw a cheaper knockoff brand at a Harbor Freight tool store in the past. I've never used it for anything myself.
In any case, if you are drilling and taping new holes, make sure you clean out the shavings.
Old January 30th, 2007, 12:11 AM   #13
Stangzilla's Avatar
JB Weld works just fine for something like this.
Old January 30th, 2007, 02:45 PM   #14
89mustanglx5.0
thnx, not sure what ill do yet. its a stock throttle body. Ill probly jbweld it. I saw a ebay auction and a throtle body went for 30 shipeed. but I can save money and just use a bit of jb weld in there and u will never even see it I think.
as a matter of fact, i wonder if i can use jb weld on the throttle body, tap new threads on the nozzle and thread the jb weld ? Its pretty tough stuff when its dry and solid. hmm. This way it can be unscrewed easy later if needed.. ...
Old January 30th, 2007, 03:17 PM   #15
RIP Justincredible! God Speed
Justincredible's Avatar
Justincredible is on a distinguished road
Used stock throttle bodies are a dime a dozen. Just replace it instead of jerry rigging it.
9.91@ 134mph 1/4 - 6.17@ 109mph 1/8th - 1.33 60' - Stock ECU & Stock Suspension......and getting faster .
BIVENS RACE CARS FTMFW!!!
Old January 30th, 2007, 04:20 PM   #16
Stangzilla's Avatar
Dude its all good the suggestions we came up with but I'll bet you Justin is right screw ebay you prob can go to yuor local scrapyard and get 1 for dirt cheap!!!
Old January 30th, 2007, 07:07 PM   #17
lineumup88's Avatar
i thought you said you were sellingthe car. it seems you are trying to rig up the whole car so you can offload it. you should remember that the people you are asking for advice are the people on the classifieds looking for good deals. you don't want to get flaged as the guy ripping people off. spend the money and fix it right
Old January 30th, 2007, 07:13 PM   #18
shadowgames81's Avatar
87 Coupe
shadowgames81 will become famous soon enough
you should just duct tape the hole shut then tape the nozzle in.....duct tape fixes anything
Old January 30th, 2007, 07:24 PM   #19
89mustanglx5.0
not what i intend at all. i want to fix it good.
Old January 30th, 2007, 07:25 PM   #20
89mustanglx5.0
that may work well!
Threads Similar to: Nitrous nozzle throttle body screwed
Throttle body? Psychojimmy 5.0 Mustangs 13 September 30th, 2007 08:26 PM
New throttle body Raven 96-98 10 July 23rd, 2007 10:23 AM
Nitrous throttle body plate 95StangSVT 94-95 0 July 17th, 2007 07:06 PM
Throttle Body Sh0gun! V6 Mustangs 16 April 23rd, 2007 08:25 PM
Nitrous Question: Nozzle vs TB Plate lil666 99-04 11 April 15th, 2007 03:53 PM
