Radiator Recommendations
Old June 9th, 2009, 10:02 AM   #1
Black Bullitt's Avatar
2001 Mustang Bullitt
Faster than Twinmill
Black Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really nice
Send a message via AIM to Black Bullitt
My buddy has a 93 Fox with a 306 under the hood. He is running the FRPP radiator, but is looking for something better that will keep things cooler. He's not really pleased the the FRPP piece. Cap on price is no more than $500. Any suggestions?
2001 Bullitt #5069
505rwhp/538rwtq @ 15#s
Originally Posted by FluffyTheRhino View Post
Nothing says "Upgrade EVERYTHING" like busted parts
Old June 9th, 2009, 10:38 AM   #2
95project is on a distinguished road
I have a Mishimoto and it works great with the mods i have. It came with twin fans that i have yet to put on because it cools fine as it is. Im not sure how it compares to FRPP though. Becool radiators are also nice just a little pricey. Go to Summitt racing site and find all you want. I got my mishimoto from latemodelrestoration.com.
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing.
Old June 9th, 2009, 10:39 AM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
He's running a Ford racing aluminum radiator with a 30 and it won't stay cool? He has problems elsewhere. A stock radiator will cool any mild 306 with no problem. I had a 91 GT years ago that ran 11.50s and never ran hot, even idling in 110 degree Las Vegas stop and go traffic. Your buddy's car has an issues somewhere and its not the radiator unless the radiator is damaged.
Old June 9th, 2009, 10:50 AM   #4
I don't think he has an over heating issue. He just want to run something cooler than what he has now. I'll have to ask him why exactly, but I know it's not running hot at all.
2001 Bullitt #5069
Old June 9th, 2009, 11:10 AM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Like I said, a different radiator will do nothing for him unless the one he has is damaged. I ran that same radiator with 562rwhp and never had an issue on the street.
The thermostat regulates the temperature. If he has a 210 degree thermostat, the engine will never run any cooler than that. If the fan clutch is bad or he has a bad fan, that will affect low speed cooling. If the plastic flap under the radiator support is missing, that will affect cooling at highway speeds. Get some more details from him. Find out how hot it runs now, how cool he wants it to run and why. If its still factory EFI he won't want it to run below 170 degrees or the computer will never go into closed loop. Performance and mileage will suffer.
Old June 9th, 2009, 11:26 AM   #6
I'll try to find out more info. I really don't know why, I just tried to help a buddy out.
2001 Bullitt #5069
Old June 9th, 2009, 11:29 AM   #7
Ok, got a response back. He said it was over heating. I didn't know about that. Before it was running fine, so who knows.
Update:
He has tried two cans of water wetter, switched t-stats, even ran it with out a t-stat...still no luck. Maybe the gauge is wrong.
2001 Bullitt #5069
Old June 9th, 2009, 11:38 AM   #8
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Update:
Water wetter doesn't work unless you run with straight water and no antifreeze. Even then it doesn't do much.
Find out if it when it over heats. Does it do it in the city, on the highway or both? What does the temperature get up to? Does the temp gauge fluctuate?
Old June 9th, 2009, 11:48 AM   #9
I'll check on those ?s and get back to you. He did say that he has a water temp gauge and just recently replaced the sending unit.
2001 Bullitt #5069
Old June 9th, 2009, 11:54 AM   #10
Here's his response.
"As long as I'm above 40mph, it stays cool which leads me to believe that it's the lack of cool water (fan). When I'm dead stopped, it'll go all the way up into the red w/ in minutes (220+). Doesn't fluctuate."
2001 Bullitt #5069
Old June 9th, 2009, 01:18 PM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Sounds like a fan or fan clutch problem.
Old June 9th, 2009, 01:24 PM   #12
Thanks for the info...I'll pass it along.
2001 Bullitt #5069
Threads Similar to: Radiator Recommendations
any recommendations 96gtstang&V6 96-98 18 November 14th, 2008 03:20 AM
Need book recommendations. Dansby The Clubhouse 24 November 5th, 2008 12:32 PM
Recommendations please El_Cangri General Tech 4 April 4th, 2007 08:56 PM
tire recommendations B0B 99-04 2 February 18th, 2007 11:16 PM
Suspension Recommendations Twist 2 Go General Tech 7 December 4th, 2005 01:08 PM
