want to build a 408w stroker. need help
Old June 9th, 2009, 09:57 PM   #1
LETHALFORDS is on a distinguished road
i just got a 351w im gunna build a 408 stroker.want to throw nitrous on it.
new to all the carb stuff any one have any recomened sites for carbs,heads
and what cam i should run? or anything?
Old June 9th, 2009, 09:59 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Pro Systems for the carb. Heads and cam depend on how much power you want to make and how much money you have to spend.
Old June 9th, 2009, 11:58 PM   #3
ok. and idk heads like 7 to 900 and cam lik 200 or so?
Old June 10th, 2009, 12:13 AM   #4
1988 LX Procharged 347
Procharged 347 is on a distinguished road
sounds like a tight budget
[SIGPIC][/SIGPIC]
[FONT="Arial Black"][SIZE="4"][COLOR="Red"]Procharged 347 stroker [/COLOR][/SIZE][/FONT]
Old June 10th, 2009, 12:40 AM   #5
1998 Cobra
13.24@105.66
better hop on corral and look for some nice canfields or AFR's used.
weeee foooord!
Old June 10th, 2009, 01:38 PM   #6
what about procomp heads?
or power house?
what should i go with for the port sizes?
Old June 10th, 2009, 01:51 PM   #7
BlessedHellride's Avatar
1988 Notchback
11.19 @ 122mph N/A
BlessedHellride will become famous soon enough
Get the 190 or 215 Pro Comps if you are on that tight of a budget. Muscle Mustangs & Fast Fords did a write up on a low compression 408W with the Pro Comp heads 190cc as cast and 215cc CNC'd. I think the larger 215cc CNC'd head version made 505hp/489tq at the flywheel and the 190cc heads were around 463hp/480tq. They made this power with a Comp Cam XFI236HR, which is a very mild cam for a 408w, it's what I run in my 347. The write up is in the February 2009 issue.
FluffyTheRhino:
One time, the tramp I was fornicating with farted, and I felt it blow my balls backwards.
1988 Notch 347 C4 w/brake 3.90 gear
11.19 @ 122mph 60' 1.67 N/A
Full Interiored pump gas car
Old June 10th, 2009, 02:44 PM   #8
coreyflipp's Avatar
1990 Mustang gt
coreyflipp is on a distinguished road
If you love pain in the ass projects like having to do alot of fabricating, tweeking shit just to make the heads bolt on, then buy procomps.
2002 gt 5-speed slow
1990 gt 5-speed junk
Old June 10th, 2009, 02:54 PM   #9
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Don't spend your money on a stroker kit then. Build a 351W and stick the money in the heads and valvetrain. $700-$900 isn't going to get you enough cylinder head to support a 408.
Old June 10th, 2009, 02:55 PM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
or power house?
Don't buy junk. Stick with good heads. Trick Flow, Canfield or even AFR. Hell, even World iron heads over the pro comp junk.
Old June 10th, 2009, 02:59 PM   #11
The Razor's Edge
White Thunder's Avatar
what about dart heads?
founder of the FTN Club
Old June 10th, 2009, 03:02 PM   #12
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
For starters, magazine articles are like movies. Good entertainment. Secondly, if I had a 408 that only made 505hp I'd probably shoot myself. 500hp out of a 408 is not hard at all. We make 540-560hp out of pump gas 347s.
Pro Comp heads are junk. They have a piss poor machining process, no quality control and they come assembled with junk bottom of the barrel parts. Even if you accepted the fact that the heads flow like shit, by the time you put good valves, springs, retainers, locks, etc. in the pieces of shit you could have bought yourself a good set of heads. Then of course there are some people that will just bolt them on and be satisfied with piss poor quality and the high failure rate of the junk parts.
Old June 10th, 2009, 03:16 PM   #13
then ill start looking at AFR or trick flow
so how big of ports should i go with
Old June 10th, 2009, 03:31 PM   #14
The Razor's Edge
225 and if you go afr upgrade the springs to your cam specs
Old June 10th, 2009, 03:32 PM   #15
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Trick Flow High Port or R-series with a 225cc intake port if you are doing a 408.
Threads Similar to: want to build a 408w stroker. need help
408w stroker questions Speedstang302 5.0 Mustangs 9 December 8th, 2008 12:08 PM
302 Stroker build 86 gt michigan maniac 5.0 Mustangs 60 December 7th, 2008 02:33 PM
Mofo Productions- LSX Stroker T/A vs 408W-C6 ZO6 inside Racerchik02 The Clubhouse 24 March 17th, 2008 09:38 PM
How to build a 331 stroker Drick 5.0 Mustangs 10 January 25th, 2008 08:57 PM
347 Stroker Build Up!!! Speedstang302 5.0 Mustangs 0 October 6th, 2007 11:28 PM
