Headgasket
Old January 28th, 2007, 04:26 AM   #1
hotrod88lsc is on a distinguished road
Headgasket
I believe that I have popped a headgasket. At high Rpm's Im spraying coolant out of the overflow tank.
I cant remember it's been so long. How long does it take to change them by yourself? I think the last time i did it I had changed the timing chain too. So I just dont remember.
Anybody remember let me know.
Mike
88 Lincoln Mark VII --- Paxton Novi 1000, gt40's Typhoon Intake, TREMEC 3550, 3.73's Nice little HOTROD LINCOLN
354.9hp/372tq
Old January 28th, 2007, 12:24 PM   #2
bigbadtalontsi is on a distinguished road
It took me about 8 hours to change my heads and intake on my car. I also took my time so i could make sure everything was perfect. You could actually do it in about half that time.
Old January 28th, 2007, 01:43 PM   #3
cobraetti's Avatar
2001 svt cobra
no way (IRS)
cobraetti is on a distinguished road
coolant out of the overflow tank?, how so
Build #1249
MM New Edge Crew Member# 6
Old January 28th, 2007, 08:28 PM   #4
Well it was coming out of the overflow, while i was messing with a camaro going down the Highway. At about 5000-5200rpm and 6psi. And then I pulled over checked it out and the overflow was all frothy and bubbles on top of the coolant in the overflow.
354.9hp/372tq
Old January 28th, 2007, 10:20 PM   #5
all motor
SALIV8's Avatar
92 coupe
9.94@136.40
SALIV8 is on a distinguished road
I would do a cooling system pressure test, or compression test. You may have boiled the coolant, do you have any leaks in the system, is the radiator cap good? is the seal good?
Old January 28th, 2007, 11:11 PM   #6
I had just fixed a leak in the hoses going to the heater core......The cap. i put on over a year ago......and to be honest it looked like it was boiling. i mean if i blew it wouldnt it be bubbling all the time? Or is it possible it's lifting the heads with the stock non-TTY bolts on there. They didnt switch bolts till 92 if i remember correctly.
354.9hp/372tq
Old January 28th, 2007, 11:27 PM   #7
Stangzilla's Avatar
Stangzilla is on a distinguished road
you have a supercharger on your lincoln very high cylinder pressure. chancer r you did blow the gasket...
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old January 29th, 2007, 12:20 AM   #8
all motor
SALIV8's Avatar
92 coupe
9.94@136.40
I woulddo a coolant pressure test, and a compression test. Highway speeds, higher rpms for a longer duration could be boiling a poorly sealed cooling system, or could've popped a gasket. keep an eye on it for loss of level, and chek your oil. make sure ur not mixing.
Old January 29th, 2007, 01:09 AM   #9
Checked the oil and not mixing at all, used a "block tester" and it's got exhaust gasses in the coolant.
I dont have access to a coolant pressure tester I just lost my job at Midas and I did have everything available to me just kindof shit out of luck right now.
354.9hp/372tq
Old January 29th, 2007, 10:38 AM   #10
all motor
SALIV8's Avatar
92 coupe
9.94@136.40
Block tester turnedcolors and i would say ur right and stangzilla- headgasket time I would do both, but u prob know that. >> also those exhaust gases will mix with ur coolant and turn to acidic corrosive liquid,<< so do it asap.
Old January 29th, 2007, 11:31 AM   #11
yeah I have the stuff to do it. I just have to get time. I live in an apartment complex and dont know if i can even do it here.
354.9hp/372tq
Old January 29th, 2007, 02:24 PM   #12
I thought that i blew a head gasket because of the bubbling antifreeze too, but turns out it was an intake manifold gasket. My head gaskets were fine, but while you are in there, might as well check those too.
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old January 29th, 2007, 07:43 PM   #13
Ill check that too Tony, Anyone got a garage i can use LOL, it's freakin cold outside.
354.9hp/372tq
Old January 29th, 2007, 08:40 PM   #14
Ask All My Baby's Mommas
lineumup88's Avatar
lineumup88 is on a distinguished road
no garage but i live in hampton and if you need a hand gettin it done i could help. i have a compressor and the know how. also if the acidic mix going on in your cooling system, the timming cover gasket should be changed to. it is a weak gasket doesn't like corrrosives
hey chevy boy.....i got something for you to POWERSTROKE!
Warning: surgeon general says its ok to smoke ricers!
Threads Similar to: Headgasket
maybe a headgasket..... sivart 5.0 Mustangs 17 August 20th, 2007 09:12 PM
Headgasket time. Woohoo!!! Few questions with SD 8A_Honda 5.0 Mustangs 4 August 1st, 2007 09:36 PM
Changed headgasket, now check engine light and barely runs. 8A_Honda V6 Mustangs 26 July 13th, 2007 01:40 PM
Headgasket 8A_Honda V6 Mustangs 14 July 5th, 2007 12:05 PM
