13.64@101mph
GT calipers on Cobra rotors
hey converting my friends 5.0 over to 5lug..and he isnt too happy about how much everyone wants for used cobra calipers...i have a set of GT (PBR) calipers front and rear...would those work with the cobra 13/11.65 rotors? i heard something about how the rotors are wider on the cobra, or some other reason..cuz the cobra brake pads are thinner than GT's...any help? can i use the GT calipers with cobra pads? i hate brakes..haha
2009 ROTY
the front calipers from the gt will not work on cobra rotors. but the rear calipers will. you will need different pads to use cobra rotors in the rear though.
13.64@101mph
so the cobra pads for the rear if i do the GT calipers on the 11.65 cobra rear rotors? and would it be sensable to just put the gt calipers and rotors on the front? also is it neccesary for that custom bracket for the rear?
2009 ROTY
the pads in the rear are thinner on the cobra's because the rotor is thicker. and the rear uses a different caliper mounting bracket to run the 11.65 rotor. the caliper are identical to the cobra's and gt's in the rear. its the mounting bracket that bolts to the diff housing that is different.
13.64@101mph
so if i cant find cobra brakes for all 4 corners before whatever the fuck his deadline is...i can use cobra rear brakes with GT calipers but with cobra bracket and pads? do i really need that northrace car bracket?
1989 LX Coupe
7.1@99mph
Jesus...
SOrry...but you are being confusing as hell. Say calipers or rotors...not just 'brakes' They have been trying to tell you...Cobras or GTs...the CALIPER is the same for the rear...just that the cobra ROTOR is thicker than the GT...hence, if you use the same CALIPER like they do...you would need 'wore' down pads or better yet...Cobra pads for the rear. Also, being the cobra rotors are bigger than the GT rotors, you would have to space out the caliper to accommodate the bigger rotors....that better? In the front. No one makes a bracket to make GT calipers work on a 13" Cobra rotor. Just get Cobra calipers and brackets and use 13" rotors. No way to get around that. Good luck.
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20 01 Bullitt-32v swapped 96 GT-Cammed E85 www.KPERacing.com |
June 2010 ROTM
2000
All the above is 100% correct.
just to repeat as easy as possible. Front: You need Cobra (PBR) Calipers, Rotors, Pads ( and possibly brake lines) Rears; You need Cobra Rotors and pads and extension brackets. Calipers are identical. thats it in a nutshell. Nothing else will work. American Muscle, and other companies sell the rear kit for about $185 bucks. Remember, you MUST pull the axles out to put the new brackets on. No way around that. They also sell the front kit with rotors and calipers. Front is a simple 20 min. swap.
HPDE Instructor PCA, HOD, Track Guys, ERME www.RaceCarTowHooks.com My Track Videos http://www.youtube.com/user/Msirlin My Garage page: http://www.moddedmustangs.com/forums...-member-17090/
2009 ROTY
^^^those two got it summed up! good stuff.
The Razor's Edge
sticky
Threads Similar to: GT calipers on Cobra rotors
| pics/rotors/calipers/headers/pedals | 07stanggt | 2005 - 2010 | 42 | March 3rd, 2008 06:06 PM |
| ranger axles 95 mustang rotors and calipers | 86ttops | 5.0 Mustangs | 0 | August 30th, 2007 08:16 PM |
| rotors & calipers | 96DropTop | General Tech | 1 | April 11th, 2007 02:17 AM |
