Project: POS - Page 11
Old August 31st, 2009, 07:13 PM   #201
fl4321 is on a distinguished road
why not remover the e-brake completely, then just cut them. nut if not take the drum off and youll figure it out. i think there is 4 little tabs youll have to push in
you dont need no teef to eat my beef
Old September 1st, 2009, 01:50 AM   #202
Nice 5.0's Avatar
1993
12.9 @ 105
Nice 5.0 is on a distinguished road
You'll have to disassemble the rear brakes to get the e-brake cable disconnected if you plan on reusing the e-brake with the new rear end.
Old September 2nd, 2009, 06:19 AM   #203
fs308's Avatar
fs308 is on a distinguished road
My brother and I got some more down tonight. i got to really think him for all the help and jon for letting me use his garage
i got some more bad news tonight. apparently when i was living at my moms and the car was sitting in the grass it started to take its toll. we also found some rusting starting in the drivers side quarter panel
87 Notch
Doing a lot with a little
_____________________________
lightweight, stock motor, and 12's?
Old September 2nd, 2009, 02:29 PM   #204
TheBrat's Avatar
91 Mustang LX Fastback
We shall see when she gets done..
TheBrat is on a distinguished road
Hurts to find stuff like that, I know my car has been ripped apart and im slowly putting it back together. And when you do a project like this, you seem to find stuff you wish you never did. Somtimes making you wish you never got that far into it.
On the other hand, if you feel like backing out of the project, ill take all those pretty parts off your hands and put them in my car If you dont, well good job! Ill post a picture of where my car stands and where I have found rust (not tryin to hijack thread of course)
2003 MazdaSPEED Protege. Lava Orange with all the go fast parts
1991 LX. 2.3T in the works.
1977 Pinto Wagon. New motor combo in the works for 2012, C4, 4.10s, 150 pill. Et. unkown
1969 Impala. Needs a resto.
Im Canadian, Eh!
Old September 2nd, 2009, 02:39 PM   #205
TheBrat's Avatar
The little yellow circles are where I have rust, I have it on both sides to in the same spots
Im Canadian, Eh!
Old September 5th, 2009, 09:32 PM   #206
fs308's Avatar
more cancer
Then i prepared some for my next outing over there
87 Notch
Old September 7th, 2009, 04:56 AM   #207
fs308's Avatar
my brother and I got some more work done. we also borrowed my buddies rims
we were trying to get an idea of how low it is so we propped the front end on
notice the wheel gap? it dont even have a motor in it yet
87 Notch
Old September 7th, 2009, 12:06 PM   #208
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
My car without the motor was still less then stock ride height of a fox. My car is slammed. I doubt you will have rubbing issues if thats your concern.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old September 7th, 2009, 04:58 PM   #209
fs308's Avatar
no i am not worried about rubbing. i will still have the height adjustment of the coilovers. i was just trying to get an idea if it was lower or not bc of the drop spindles
87 Notch
Old September 10th, 2009, 03:02 PM   #210
fs308's Avatar
the front end is pretty much done with mock up except for putting the brake pads in and the other bumpsteer/ tire rod arm on.
8.8 with disc brakes. the disc brakes are of no use to me nor are the axles so i will probably try and sell them
another look with the new rims. i also took some time and lowered the jack stands to get an idea of what it would look like
full car shot with the 17in 00-02gt rims
87 Notch
Old September 10th, 2009, 03:27 PM   #211
91 LX
13.7@101
sweet man keep up the good work
Old September 10th, 2009, 03:38 PM   #212
fs308's Avatar
i picked up an 8.8 i have to get it cleaned up and then have to take it to bivins race cars to get that 9in ends put on axle tubes welded up and then assembled.
after that the car will be a roller again. i will put the team z rear suspension under and then take it back to bivins to have the through the floor subframe connectors, weld up the torque boxes a chromoly trans mount and a little front end tweaking
87 Notch
Old September 10th, 2009, 04:58 PM   #213
91 LX
13.7@101
what engine are you putting in it?
Old September 11th, 2009, 12:07 PM   #214
fs308's Avatar
a 308
87 Notch
Old September 12th, 2009, 04:04 PM   #215
EscortSportage's Avatar
1989 Mustang GT 5.0
ill be puttin up pics like this soon, good work so far!
10 point Cage
Bunch of newer mustang parts
Maximum Motorsports catalog
Sparco stuff
"a huge bad azz motor is nice untill you have to turn or stop"
Old September 12th, 2009, 04:37 PM   #216
fs308's Avatar
thanks going to do some more work tomorrow. power washing the rear end and then hitting it with the wire wheel to get some of the rust off it. then power washing the bottom of the car.
also plan on getting the rear suspension in the car
87 Notch
Old September 20th, 2009, 03:29 AM   #217
fs308's Avatar
the rear end has been dropped off. the way they are talking i should get it back sometime next week. its getting put together with
9in ends
welded axle tubes
strange rear end cover
strange rear end pinion
4.10 gears
strange 33spline spool
moser 33spline axles
87 Notch
Old September 20th, 2009, 10:52 AM   #218
baine21225's Avatar
that will be a stout little rear
"Whip out your dick you'll either get it sucked or get smacked..."
Old September 21st, 2009, 06:29 PM   #219
blackstang2004's Avatar
blackstang2004 is on a distinguished road
man this build it going good. looks great too. where in KY do you live. i live in Albany.
DD-2002 Tacoma 4x4
2004 Mustang GT- sold "will be missed"
Old September 22nd, 2009, 02:40 AM   #220
fs308's Avatar
owensboro
87 Notch
Threads Similar to: Project: POS
Another POS! Regency 2007 The Clubhouse 1 March 11th, 2008 02:00 AM
need help pos unit tom2000r 99-04 12 February 25th, 2008 07:46 PM
Project pos car stage one supercharged04 Pictures 5 January 25th, 2008 08:48 PM
87 dakota POS Ninjawafers! All Other Vehicles 1 January 15th, 2007 06:13 AM
