Discussing Project: POS in the 5.0 Mustangs Forum. Looks good man, can't wait to see the build get underway...... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#61 |
1988 GT
#62 |
Zippee is my step sister.
1990 Mustang LX
9.36@143 mph
If you are trying to get the most out of the car then yes. A light weight, low friction rear axle will take less horsepower to operate. Will there be a night and day difference, no. Will it be faster, yes. I had Mark Williams gun drilled 35 spline axles and a chromoly gun drilled spool in my black notchback. That car performed.
Thanks to: Trick Flow, Team Z Motorsports, Total Engine Airflow and Furo Racecraft My daily driver has 16 cylinders and 4400hp @ 1000 rpm....
#63 |
with my goals should i do it then? its around 100 more when i buy my gears and axles from strange
![]() 87 Notch Doing a lot with a little _____________________________ lightweight, stock motor, and 12's? |
#64 |
1990 Mustang LX
9.36@143 mph
If it was my car and I had the extra cash to do it, then I would do it.
#65 |
Team Z rear suspension was ordered today. dave said it should be here monday or tuesday.
1slo5.0 i can save the extra little bit. if thats the case i will have it done when i order my gears and axles
#66 |
1988 GT
What did you end up going with? I'm planning on ordering mine next Thurs. just wondering because our cars/parts seam to be very similar, lol
#67 |
strip series 1
#68 |
so i was just sitting here thinking ive still got a lot to do before i can even get this car going.
i need: rear brakes gears axles 9in ends a motor (big duh) trans rear shocks driveshaft trans mount and wheels and tires also since the car was a 4cylinder car dont have to run brake lines to make it disc brakes in the back?
#69 | |
89 gt Hatch
How fast can zippie go down?
![]() Lakewood Uca's/lca's. FMS clutch w/Adj. , Hurst shorty, aluminum d.s. 3.73's Black Stang Crew Co-Founder The blood i bleed is black indeed |
#70 |
4.10's
#71 |
it all takes timd
"Whip out your dick you'll either get it sucked or get smacked..." "That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
#72 |
89 gt Hatch
im selliing my set of 4.10's with the gasket synthetic oils and additive and rear chrome cover. actually posting now as we speak. im hoping to get decent cash its was all extra with this gt i got. plus still have an entire interior to get rid of.
#73 |
I'm also selling a brand new in box set of 4.10's with a FULL install kit including axle bearings, let me know because they are going on ebay otherwise
#74 | |
89 gt Hatch
#75 |
yea, that just happened
#76 |
1988 GT
LMAO, I too am selling a set of 4.10's.... No i'm not, but real quick If you planning on buying strange parts and all that why not just by a housing from them? with everything else you need
#77 |
thats what i been thinking about. i think i am going to go 9in also. so i think my strange spool may be for sale. i dont think a 8.8 spool will work in a 9in rear unless someone can clarify for me
#78 |
1988 GT
Whats wrong with using the 8.8?
#79 |
there really isn't a reason to go with a 9 in if you already have the 8.8 stuff....they can be basically indestructable
#80 |
i would have to buy everything pretty much thats why i am considering doing the 9in.
also i may be picking up a cowl hood this weekend if everything works out
Threads Similar to: Project: POS
| Another POS! | Regency 2007 | The Clubhouse | 1 | March 11th, 2008 02:00 AM |
| need help pos unit | tom2000r | 99-04 | 12 | February 25th, 2008 07:46 PM |
| Project pos car stage one | supercharged04 | Pictures | 5 | January 25th, 2008 08:48 PM |
| MM+FF PROJECT CAR F/S 86 notch project frightning | kaboom | For Sale | 2 | February 4th, 2007 05:33 AM |
| 87 dakota POS | 3.8Coastie | All Other Vehicles | 1 | January 15th, 2007 06:13 AM |
