Oil in EGR spacer???
When i took my throttle body and IAC off to clean i noticed there was a pretty good amount of oil sitting in my EGR spacer.
is that normal? or is this something i have to worry about?
Too often, We lose sight of life's simple pleasures. Remember, when someone annoys you it takes 42 muscles in your face to frown, BUT, it only take 4 muscles to extend your arm and bitch-slap that Mother@#?!&! upside the head!! |
11.47@120.58
It's from your PCV system, it's normal. It's a probably good idea to clean it up though and replace the PCV valve. Some people go with catch cans or whatever so they don't have to muck up their intake.
yeah i guess i should go a head and replace it. now to get to the damn thing. lol. i know where its at but i cant see the thing.
Common, Yes. Normal, No. The resion you have that much oil in there is prob due to blow by. Most of these 5.0's are older and the wear on the motors causes blow by that pressurizes the crank case and vents more than normal air into the TB bringing some oil with it. If this is a big problem rebuild the motor.....ok out a breather on the valve cover not the oil cap and that help alot.
plug the vac line on the valce cover..no need in sucking in oil
Threads Similar to: Oil in EGR spacer???
| G10 intake spacer | Juggalo_X | V6 Mustangs | 27 | June 24th, 2007 12:35 PM |
| intake spacer... | ByPopularDemand | V6 Mustangs | 15 | May 24th, 2007 09:42 AM |
| spacer | droppedbass87 | Visual | 6 | May 15th, 2007 02:28 PM |
| whats with the egr spacer | nateo | 5.0 Mustangs | 7 | April 9th, 2007 07:48 PM |
| spacer | mustang1072 | V6 Mustangs | 50 | February 10th, 2007 02:10 AM |
