Trick Flow Twisted Wedge Fast As Cast vs Trick Flow® Twisted Wedge Street
Old June 16th, 2009, 09:04 AM   #1
Timm10221's Avatar
88Notch 10.59 @132 / 03 Mach 1 13.1 @104
Timm10221 is on a distinguished road
How much of a gain would the fast as cast get you over the street heads that come with the trick flow top end kit. I am looking to buy this when i get home.
Trick Flow Specialties TFS-K514-360350B - Trick Flow® 360 HP Twisted Wedge® Top-End Engine Kits for Ford 5.0L – SummitRacing.com
Military Crew USMC
Originally Posted by JBIGBOOTSY
I usually kill the hookers(so I don't have to pay them) then I take their hands for my collection.
Originally Posted by homebrewed
Perversion mixed w/ mild tech... God I love ModdedMustangs!!
Originally Posted by flyin ryan View Post
Three Filipino hookers and enough for a co pay at the local clinic
Old June 16th, 2009, 10:25 AM   #2
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
yeah darrell....break down a comparison for us
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old June 16th, 2009, 10:53 AM   #3
kilby91's Avatar
1991 Mustang GT
kilby91 is on a distinguished road
I was reading up on these heads on a different forum, and a very credible source was talking about these heads.. Here is what he wrote:
"There is a 170cc head. This 170cc head can be CNC ported to 185cc or 205cc.
There is a porter's casting that is made exclusively to CNC. They end up at 185cc or 205cc. This makes a lot BETTER piece than if you just CNC'ed the OOTB 170cc head.
Then there is a 190cc Fast As Cast head. This head was designed off of the 185cc CNC head. It is priced for those on a "budget". It is 400.00 - 500.00 CHEAPER than its CNC cousins and in its intended market, there is not another head you can and spend no money on that is going to out run it. This head has a CNC chamber (standard, no extra cost) and a CNC bowl blend (standard, no extra cost) that just knocks the lip off of the seat."
From what i have heard from people that i have talked to, the FAC 190 heads are hard to beat.. But on the other hand the TW 170cc head is a great piece also...
Old June 16th, 2009, 10:55 AM   #4
Lind's Avatar
1994 Ford Mustang GT
Lind is on a distinguished road
well just comparing numbers right now...
combustion chamber: 64 vs 61
intake runner: 190 vs 170
exhaust runner: 66 vs 61
those look like the only differences that i can see on paper
Trick Flow® Twisted Wedge Fast As Cast Cylinder Heads for Small Block Ford: TFS-51400015 - trickflow.com
Trick Flow Specialties TFS-51400010 - Trick Flow® Twisted Wedge® Street/Strip Cylinder Heads for Small Block Ford – SummitRacing.com
www.moddedmustangs.com
Old June 16th, 2009, 11:40 AM   #5
Timm10221's Avatar
Yeah those are the only diffs i see too... I would rather the 61 CC for higher compresion, becuase i am going for a NA setup, with nitrous down the road. But yeah if they are a ton better then i will piece together a top end kit instead of going with the premade one...
Military Crew USMC
Old June 16th, 2009, 11:48 AM   #6
coreyflipp's Avatar
1990 Mustang gt
coreyflipp is on a distinguished road
[QUOTE=Timm10221;2134324]Yeah those are the only diffs i see too... I would rather the 61 CC for higher compresion, becuase i am going for a NA setup, with nitrous down the road. But yeah if they are a ton better then i will piece together a top end kit instead of going with the premade one...[/QUOTE]
Good idea. Def go with the fast as cast. Why not?
2002 gt 5-speed slow
1990 gt 5-speed junk
Old June 16th, 2009, 11:56 AM   #7
Timm10221's Avatar
Yeah and get a custom grind cam too
Military Crew USMC
Old June 16th, 2009, 12:11 PM   #8
coreyflipp's Avatar
1990 Mustang gt
That's the word on the street
Old June 16th, 2009, 12:34 PM   #9
Timm10221's Avatar
I am waiting to see what 1slo5.0 sayz about them!! I think i know what he will suggest
Military Crew USMC
Old June 16th, 2009, 12:39 PM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I have not run these heads yet but from what I hear they are a top notch head, like everything else Trick Flow sends out the door. What Kilby91 quoted is right out of Jay Allen's mouth on a few other sites. All factual.
Have the heads milled to get the chamber back down to 61cc or smaller if you want. That is not a big deal at all.
Old June 16th, 2009, 12:40 PM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Only differences? Its a totally different head. Those differences are not small differences and shouldn't be worded as "the only differences".
Old June 16th, 2009, 12:41 PM   #12
Timm10221's Avatar
What would my compression be if i didnt??
Military Crew USMC
Old June 16th, 2009, 01:15 PM   #13
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Roughly 8.7:1 on a stock Mustang engine. Too low. I'd have them milled to 54cc and bring compression up close to 10:1 if it was my engine.
Or you can just buy a Canfield 192cc head that comes in either 54, 58 or 61cc chambers.
Old June 16th, 2009, 01:16 PM   #14
Lind's Avatar
you took the time to quote it why didnt you read the whole statement, i said on paper, i know its a completely different head (casting, air flow, application wise)
Old June 16th, 2009, 01:21 PM   #15
Timm10221's Avatar
wow that is low... the 61cc will be 9.somthing:1.. so youd go for a 54 cc, this is ok on a stock bottom end?? Do you get more gains with the high compression?
Military Crew USMC
Old June 16th, 2009, 01:36 PM   #16
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I read the whole statement and replied to the whole statement. "Only differences" is big differences in this case.
Old June 16th, 2009, 01:41 PM   #17
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Yes a stock bottom end is ok. Gains won't be huge but the gain will be across the entire rpm range. Higher compression equals greater efficiency which equal more horsepower.
Threads Similar to: Trick Flow Twisted Wedge Fast As Cast vs Trick Flow® Twisted Wedge Street
systemax and twisted wedge 1BADSTANG 5.0 Mustangs 4 May 10th, 2008 12:34 AM
twisted wedge heads flattusmaximus78 5.0 Mustangs 10 March 24th, 2008 12:54 PM
Twisted Wedge mustangfox9091 5.0 Mustangs 10 November 18th, 2007 07:32 PM
Trick Flow Twisted Wedge 5.0L EFI Engine Kit matty1157 94-95 8 June 21st, 2007 12:10 AM
twisted wedge dr.gonzo! 5.0 Mustangs 3 January 26th, 2007 02:46 PM
