headlights arnt bright
im needind help a did the fog light fix a long time ago bc they stopped working and the foglights are brighter than the headlights on bright. i have new headlight bubls and clear headlights is there anyway i can make em brighter mayb run a relay to em like i did the foglights
5.0, steeda short shifter, edelbrock intake upper and lower, bbk cold air intake, 3.73, b303 cam, 65 mm throttle body, 65mm mass air, 24 lbs injectors, h pipe, dual flows dump and more to come
i found this and i think ill try it brighter lights
i think im going to try this out tomorrow
The Razor's Edge
Hid kit
1988 GT
Make sure all your grounds are nice and tight... no joke, the ones just above the headlights where the hood prop sits, if those aren't tight or have good contact that could be the source of your problem... GL
i know the hid kit will make em brighter but i dont wanna spend all that money... and ill check the grounds
1988 lx
13.13@101.78
i got a 6000k hid kit in my lx and it only cost me 50 bucks off ebay.
![]() 302 out of a lincoln lsc, Cobra upper and lower, 1.6 rr's, msd cap, bbk equal lengths, off road h pipe, mac pro chambers, 4:10's, bbk drag launch springs, 4cylinder tranny, short shifter, 20% tint, and 6k H.I.D's. 13.13@101mph 1.8 60ft on D/R's |
#8 | |
+1 or bulb choice you try silverstars?
88 5.0 with bbk shorties, bassani x-pipe w/o cats, custom 2.5in w/flowmasters. t-5 conversion, gt40p heads cobra upper and lower. stock SD. Plans: full black interior, black paint and supercharger??? |
SVTfocus, F250
is your harness loose or damaged on the dash switch or turn signal switch?
meh
Do they work well? I have seen them in stores, but I've never tried them.
'87 2.3 Notch with +4 cylinder mod ![]() Ass, Cash, or Grass.. nobody rides for free Black Stang Crew Member #11 |
i have them and i like them for the price you pay. if you want to blow uber amounts of dollars go with the HID kit
Authorized Vendor
![]() Join Date: Sep 2008
I'd go with relays and overwattage bulbs if the relays aren't enough. A lot of the HID kits throw out the extra light in random directions rather than where you need it.
Silverstars FTL.
In my opinion, they may be "slightly" brighter in tests but nothing you would notice in real life AND, they have a rated life of about 150 hours compared to regular halogen bulbs that are usually rated for about 1500 hours. Add in the fact they are usually $10-25 more per pair so in the long run they have an effective cost of about 15x to 20x more than the Slyvania Xtra-Vision bulbs. I ran several pairs in the past and got an average of 3 months before they burned out. One trip, one burned out about 2 hours after the other one and I had to use my high beams. Maybe they've changed in the last year or so but I will never waste my money on those overrated overpriced POS Silverstar bulbs again. Sorry about the rant
SVTfocus, F250
i just got the napa brand "white" bulbs and they work great for a good price
ive had mine for almost 3 years now and not one problem. i guess its the luck of the draw
The Razor's Edge
for the price of them you could get a hid kit
1988 lx
9.68@142
deffenitly check the grounds it makes the world of difference. you should not have to wire in a relay thats trying to fix a symptom to a problem insted of fixing the problem. and trust me 50% of the time fixing a symptom uausally leads to a much worse problem. its like taking a pill for a headach but the side affect is dihrrea, runny nose, blood clots, and aids.......well at least the headach is gone right......
#18 | |
It is not my bad luck, they are rated by Slyvania for roughly 150-180 hours average life and from my experience, that is pretty accurate. You must be significantly beating the averages or you do not drive at night ![]() OSRAM SYLVANIA - SilverStar The car I had them in took an H4 which was 150 hrs, the 9004 for the Fox is 180 hours. "More Info" under the specific bulb shows the specs.
1988 GT
LMAO!!! interesting analagy...
the grounds looked good but i put in the relay anyways and it made it bright enough to see and when i get my new foglights everything should be a bit better
Threads Similar to: headlights arnt bright
| my sister isn't too bright... | ItaliStang | The Clubhouse | 34 | April 16th, 2009 09:01 AM |
| What to do? HIDS too bright? | suzuki827 | 2005 - 2010 | 15 | April 6th, 2009 12:39 PM |
| Bright bulbs for new headlights but not ghettosmashers | 1911A1 | 5.0 Mustangs | 20 | March 31st, 2008 06:43 AM |
| light bright | JASonic | Visual | 16 | August 30th, 2007 08:42 PM |
| Lord help me I'm not that bright | stonecold316 | 2005 - 2010 | 3 | February 21st, 2007 11:53 AM |
