setting up pedestal rockers?
Old June 21st, 2009, 06:21 PM   #1
78mach1's Avatar
78mach1 is on a distinguished road
Send a message via MSN to 78mach1
alright so on my 78 with a 306 in it, i am running 7:1 roller pedestal rockers and im thinking i have an issue with them, i know how to adjust a stud rocker but what is the rule for pedestal?
my car has developed a miss fire but my compression is even across the board.
Old June 21st, 2009, 09:25 PM   #2
86er's Avatar
all you can do is put a small shim under the stand, otherwise you just torque them to like 18 or 20 lbft
Just a truck
Old June 22nd, 2009, 02:12 PM   #3
78mach1's Avatar
well i just ordered the shim kit, im curious what kind of problems could have developed from them not being adjusted correctly.
the engine has about 1k miles on it
Old June 22nd, 2009, 04:48 PM   #4
Did you measure for psuh rod lenght?
PeteAndersonRacing.com
Old June 22nd, 2009, 08:59 PM   #5
78mach1's Avatar
no, i used stock length pushrods.
should i have mesured?
Old June 22nd, 2009, 10:55 PM   #6
Always measure
Old June 22nd, 2009, 11:03 PM   #7
88-gt-t-top's Avatar
1988 GT
88-gt-t-top is on a distinguished road
Aren't there two ways of doing this...A) using the proper tool B) Turing the motor over and watching where the rocker hits on the valve stem when the valve is open. I'm assuming one is more accurate than the other, I was just looking for some insight and if you've heard of method "B"?
Originally Posted by 1slo5.0 View Post
You never save anything when you buy cheap off brand junk.
Originally Posted by e3sean View Post
its like taking a pill for a headach but the side affect is dihrrea, runny nose, blood clots, and aids.......well at least the headach is gone right......
Old June 23rd, 2009, 03:01 AM   #8
78mach1's Avatar
Always measure
they were stock heads with stock valves/springs, the only thing i changed where the rockers and the cam.
Old June 23rd, 2009, 03:06 AM   #9
1992 Lx
11.39@119.24
thats why you measure
Threads Similar to: setting up pedestal rockers?
Pedestal conversion kit for gt40p's? 93hatch 5.0 Mustangs 1 June 20th, 2008 05:09 PM
Pedestal mount limits fogged306 5.0 Mustangs 3 May 14th, 2008 07:49 PM
Setting Roller rockers turbong 5.0 Mustangs 6 November 22nd, 2006 07:43 AM
