No Oil Pressure !!
Old June 23rd, 2009, 01:41 PM   #1
ridebmxfbm's Avatar
1988 Mustang GT Vert
ridebmxfbm is on a distinguished road
No Oil Pressure !!
I have no oil pressure as per the gauge on the dash, and I know there is non from the knock, checked the oil level its fine, then changed the oil, and now it still knocks bad... and there is no oil pressure at all..
1988 GT Vert- 306 AOD built Trans, K&N Cold Air Intake, Mac Catback, many more mods... MAC Long Tubes Coming soon, Dr. Gas Custom X Pipe, 347 Stroker Kit Coming Soon...
Old June 23rd, 2009, 02:09 PM   #2
1986 mustang gt
1fst5.0 is on a distinguished road
u might have spun a bearing
Old June 23rd, 2009, 02:13 PM   #3
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
if you have no or low oil pressure, like stated about its either a worn out main bearing or spun main bearing
Old June 23rd, 2009, 02:21 PM   #4
ridebmxfbm's Avatar
yup no oil pressure and it just knocks...
Old June 23rd, 2009, 02:23 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Many possible causes. The common ones are broken oil pump shaft, failed oil pump or bearing issues. Usually with bearing issues you will have some pressure, especially when cold. I'm going to say its the pump or the shaft causing your problem. Either way, the engine needs to come out and be torn down. Knocking indicates damage and is causing more damage as it keeps knocking.
Old June 23rd, 2009, 02:26 PM   #6
ridebmxfbm's Avatar
Thanks guys I guess my 347 is going to have to come sooner then I thought... more money damn it
Old June 23rd, 2009, 03:06 PM   #7
ridebmxfbm's Avatar
How much would it be for the oil shaft and/or pump if needed with replacement... ?
Old June 23rd, 2009, 09:44 PM   #8
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
About $20 for a shaft and $25 for a pump but its too late for that. The engine is knocking, the engine is phucked. If you would have shut it down as soon as the pressure went to zero then you would have had a chance to save it.
Its a good excuse to build a 347.
Old June 23rd, 2009, 09:55 PM   #9
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
Threads Similar to: No Oil Pressure !!
Oil Pressure... puppynut5 Classic Mustangs 7 September 12th, 2008 08:43 AM
no oil pressure OneBoredGuy 4V / SVT 10 June 9th, 2008 07:17 PM
oil pressure skid6 5.0 Mustangs 3 August 10th, 2007 11:50 AM
oil pressure oasr87 V6 Mustangs 4 July 16th, 2007 12:40 PM
Oil Pressure fordpat General Tech 1 December 2nd, 2006 04:21 PM
