No spark :(
Old June 24th, 2009, 12:36 PM   #1
I'm Hella From Nor*Cal
707Stang's Avatar
2008 GTI
14.65 @ 99.83
707Stang is a jewel in the rough707Stang is a jewel in the rough707Stang is a jewel in the rough
No spark :(
so last night while tinkering with the car, trying to get it started, i noticed i wasn't getting any spark at all even from the coil.... this is what i have hooked up to the coil right now. i have the one that comes from the engine harness, and from the condenser on the + side and i have a ground on the - side with the middle obviously going to the dizzy. It seems like i'm missing something but have no clue what it is...
suggestions? oh! and my points arent sparking either......
The Curse 600 CFM Edelbrock, Hookers, Pertronix billet dizzy, Accel coil, GT40 heads, 5.0 h.o, dynomax exhaust, SSBC, FRPP 9mm wires, tci
Old June 24th, 2009, 12:51 PM   #2
Proud American
MustangMatt96GT's Avatar
Im having the same damn issue with my car where it wont spark... only thing holding me back from the races tonight....
But sounds like you have it wired correctly. whats your battery voltage when you are spinning the engine over?
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old June 24th, 2009, 01:03 PM   #3
707Stang's Avatar
2008 GTI
14.65 @ 99.83
shitty deal man.
it's an optima red top that's all good and ready...
Old June 24th, 2009, 01:07 PM   #4
Proud American
you need to see what the cranking voltage is though. some ignition systems dont run with less than 9 volts.
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old June 24th, 2009, 01:28 PM   #5
707Stang's Avatar
2008 GTI
14.65 @ 99.83
oh! ok gotcha...... .. . . .. . what and how do i check that?
Old June 24th, 2009, 01:40 PM   #6
Safud: MM's Resident Hadji
Safi's Avatar
00 v6 & 99 Cobra
Safi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud of
Send a message via AIM to Safi Send a message via MSN to Safi Send a message via Yahoo to Safi
You can use a volt meter and have someone crank the car and you check the readings
Originally Posted by asiansensation78 View Post
Yeah Safi beat me on OG status lol
Old June 24th, 2009, 01:42 PM   #7
707Stang's Avatar
2008 GTI
14.65 @ 99.83
damn it. that means i gotta find one.....
Threads Similar to: No spark :(
NEED HELP Please. NO SPARK AGAIN noyz25 5.0 Mustangs 9 August 15th, 2007 06:08 PM
not getting spark right away beheivjer Modular Mustangs 8 May 30th, 2007 02:33 PM
No Spark???? brent_cosenza 99-04 11 April 16th, 2007 08:41 AM
no spark blackstang333 5.0 Mustangs 10 March 22nd, 2007 06:07 PM
No Spark need help Booger 5.0 Mustangs 4 December 30th, 2006 12:30 AM
