please help me hook up my choke
I cannot for the life of me find a suitable source to hook the choke heater too. I know its supposed to be hooked up where it only gets power when iginion is ON, but i dont want to run a full 12v to it, as I hear it can prematurely wear out the choke. (last tiem i did it, after half an hour, i touched it and scalded my fingers on the plates)...and i found two random wires that have 5v going though them, but thats not enough. And no wires off my alt are arround 7-9v which is what im looking for?
splice into the radio or ign coil power wire
Just a truck 5.4 3v: 264hp 317ft lbs rock stock piecing together the next project faster than your first sexual experience |
If you want to lower the voltage you will need to get a ballast resistor like the old Chryslers used (and some Accel/Mallory ignitions) Put it in series with your 12 Volt source, the radio power line would work, but under the hood wiring should have a switched 12 v to the EEC module. You just may not get your carb choke to fully open if it's not enough voltage.
What year of Mustang, might be able to get a wiring diagram to help you out. |
Threads Similar to: please help me hook up my choke
| Never Choke in a Restaurant in the South! | wrksnfx | The Clubhouse | 12 | February 14th, 2009 02:33 PM |
| 4 barrel carb w/ electric choke | BrandonxSD | Classic Mustangs | 8 | June 22nd, 2008 08:38 PM |
| Think I'm gonna have to choke a bitch!!! | futureMACH1racer | The Clubhouse | 98 | June 21st, 2008 05:20 PM |
| Carb only Runs at FULL CHOKE | galzamar | 5.0 Mustangs | 20 | April 26th, 2008 08:07 PM |
| I'm going to choke a b****!!! | Breakout | The Clubhouse | 92 | April 9th, 2008 05:03 PM |
