Discussing NEW MOTOR BUILD in the 5.0 Mustangs Forum. i have a block and crank now the block is a 302 .040 over 4 ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1983 GT
UNKNOWN
NEW MOTOR BUILD
i have a block and crank now the block is a 302 .040 over 4 bolt main with main girdles and lifter valley girdles and i will be using flat top hypruetec pistons, forged rods, edelbrock victor jr heads, comp high energy 292 cam, magnum roller tip rockers from comp cam, victor jr intake, 850cfm 4bbl edelbrock carb, and flowtech long tubes also a full msd ignition. how much HP can i expect from this setup?? roughly?? im thinkin no more than 300
1983 FOX BODY-LIL SOMTHIN IN PROGRESS |
Ask All My Baby's Mommas
it sounds like you are gonna have to much carb for a n/a 308. as for hp it should make 300 or so
hey chevy boy.....i got something for you to POWERSTROKE! Warning: surgeon general says its ok to smoke ricers! |
Zippee is my step sister.
1990 Mustang LX
9.36@143 mph
Carb is too big and I wouldn't use that cam. What kind of block is it? Must be a motorsport or other aftermarket block if it has 4 bolt mains. Why buy a good block and skimp on the rest?
Thanks to: Trick Flow, Team Z Motorsports, Total Engine Airflow and Furo Racecraft My daily driver has 16 cylinders and 4400hp @ 1000 rpm....
1990 LX hatch
I'd say 225hp. but with the MSD 300 sounds right. Good choice on the hypereutectic pistons, the 4 bolt main should be einough to handle them.
1983 GT
UNKNOWN
its a block from the local speed shop the first and last mains are 2 bolt but the inner are 4. its been bored out and cleaned with new cam bearings and freeze plugs. as for the carb, 650 wasnt big enough so i want something i can work with. i can always turn it way down but when i do more mods to the motor i want enough without spending another $500-$600. besides nobody said i might not spray at the track. as for the cam i want one with a rough idle so it sounds mean but i want to produce good power. if anybody has any tips then let me know something. i know i am going to have to have new heads now or atleast one so instead of getting stock i am going to get the victor jr's for sure. the specs are 210 intake and 75 exhaust with a 60cc combustion chamber. the valve sizes are 2.05 intake and 1.6 exhaust with dual springs. the maximum valve lift is .650in. the cam i am now looking at is the
XE284H-10 comp cam. duration is 284 intake and 296 exhaust with a valve lift of .541int/.544exh. sounds like it will work to me. anybody have any pointers??? also how do i put pictures in my post i took off my passenger side head today to show one piston shattered and one with a hole in it and i would like to post the pics
#6 | |
Good choice on the pistons!! Freekin funny dude good 1!!!!
Well its not a 4 bolt main block then. If it was the first and last caps would be the ones with 4 bolts. They are the main caps...
#8 | |
1990 Mustang LX
9.36@143 mph
#9 | |
1990 Mustang LX
9.36@143 mph
#10 | ||
1990 LX hatch
#11 | ||
Official MM Zeppelineers. Crew member #1 - Captain http://i170.photobucket.com/albums/u...m134137df1.jpg |
1990 LX hatch
the are really ok, but they have a high silica content to make less thermal expansion, that is a good thing. You can do stuff like run tighter cleareance, but the downside is that they are brittle and can resist less detonation. they are not really good for power adders or high comp.
![]() I <3 Econobarns AFR graph. |
#13 | |
ok good, I'm planning on rebuilding my engine this summer and was planning on using those since I will remain N/A. I was worried there for a minute.
#14 | |
1990 LX hatch
#15 | |
#16 | |
1990 Mustang LX
9.36@143 mph
carb is way to big stock 5.0 i think came with 650 cfm and what your building basically that but with a few good things.. Might be better off buying a 5.0 motor get it bored and just part out what you dont want so you can make some money and just build up from that block.
so then that block is not a 4 bolt main then?
Its a 4 bolt block, run a 750 the vic head will be happy with that, and make sure to follow KB's hyper giudelines for ring gap or you WILL pop the head off those hyper pistons. Yes you can run tighter piston clearances but guys gap them just like a forged slug and pop the heads off the hypers. When you can buy a probe srs 2618 piston for 400
It really doesnt make any sense to run those kb's.
+1
Threads Similar to: NEW MOTOR BUILD
| motor build | quickstang281 | 96-98 | 0 | November 7th, 2007 08:34 PM |
| re-build or crate motor? | tlr96 | 96-98 | 1 | March 13th, 2007 04:56 PM |
| Motor Build up | GT 849 | Power Adders | 7 | December 19th, 2006 12:46 AM |
| Motor Build And Swap | 5.0mustang9509 | 5.0 Mustangs | 2 | November 8th, 2006 10:25 PM |
| Motor Build | DragonFreak | 96-98 | 2 | September 3rd, 2006 08:35 PM |
