got a foxbody notch...yay!!! - Page 2
Old July 1st, 2009, 08:09 PM   #21
streetscraper1's Avatar
96 Boosted GT
streetscraper1 is on a distinguished road
i changed the spark plugs, plug wires, cap and rotor, and did an oil change today....and now im only getting 10lbs of oil pressure at idle...and 30lbs while im driving....and it still shakes badly under load...??? im gonna do a compression test later and see what i come up with??? what do you guys think abt my oil pressure problem???
Old July 1st, 2009, 08:13 PM   #22
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
Are you using a stock guage? If so get an aftermarket guage asap. If you do get a new guage and it still reads 10 psi, yes thats a problem.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old July 1st, 2009, 08:20 PM   #23
88-gt-t-top's Avatar
1988 GT
88-gt-t-top is on a distinguished road
That first pic doesn't do the car justice, I like it, but thats me... +1 on a new color for wheels(if you have the cash I'd get them powdercoated not rattle can)
Just noticed your passenger door panel... did someone break into the car or...?
Originally Posted by 1slo5.0 View Post
You never save anything when you buy cheap off brand junk.
Originally Posted by e3sean View Post
its like taking a pill for a headach but the side affect is dihrrea, runny nose, blood clots, and aids.......well at least the headach is gone right......
Old July 1st, 2009, 08:38 PM   #24
96 Boosted GT
it has an aftermarket guage...does it matter if the line going to the oil pressure guage has oil AND air in it....or is it supposed to be all oil in the line???
yeah im planning on getting them powdercoated black but money is kinda tight right now so im just gonna rattle can them...and the door panels are just really dry rotted and cracking...so i need to get better ones!!
Old July 3rd, 2009, 08:39 PM   #25
96 Boosted GT
bump on the oil pressure guage question above!!!!
Old July 3rd, 2009, 08:45 PM   #26
1989 LX coupe
calgarynotch is on a distinguished road
looks alot like my car
Old July 3rd, 2009, 10:23 PM   #27
96 Boosted GT
thats a good looking car
Old July 4th, 2009, 12:26 AM   #28
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
No, it doesn't matter. When you shut the car off some of the oil drains back into the engine so there will be air in the line. 10lbs at idle is low. If this started after the oil change then I'm sure they dumped a bunch of Lucas additive or gear oil in to thicken the oil so the pressure would be higher when you test drove it. Time for a rebuild. As far as the rough running, did that start after you did the tune up or has been like that since you bought the car?
Old July 4th, 2009, 12:38 AM   #29
96 Boosted GT
yeah im pretty sure it was gear oil...it smelled like gear oil...as far as the rough running it was like that when i bought it...like i said the motor and whole car shakes when the motor is under load....it stops when im coasting...so how much am i looking at for a rebuild???
Old July 4th, 2009, 01:01 AM   #30
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Its probably got a dead cylinder. A rebuild will probably cost you $800+ in parts alone and another $1200 or so in labor. These a rough prices. You will have to call around for a quote to get an accurate price.
Old July 12th, 2009, 09:00 PM   #31
96 Boosted GT
ok so i did a compression test on my car and got the following results...
cyl.1= 120
cyl.2=120
cyl.3=125
cyl.4=120
cyl.5=120
cyl.6= 0
cyl.7= 0
cyl.8=125
took the plugs out and found that all the plugs on the left bank look brand new...the plug on cyl. 5 is a brown rust color...the plugs on cyl. 6&7 are very black and smell like gas (fouled)...and cyl. 8 plug is covered in oil...but doesnt look fouled...my guess is i have valve train issues...but what do you guys think???
here go some pics..the plugs are in the order they were in inside the motor...
Old July 12th, 2009, 09:19 PM   #32
ryans88gt's Avatar
Number one Autolite 26s are way too hot of a plug to run in a supercharged car.
You need 23s most likely, 24s at the most. So now you know why you have a blown head gasket. Also looks like there is an oil control issue, but that could also be from the blown gasket. Probably wouldn't hurt to tighten the gap on the new plugs up to about 30 thou after you get done replacing the head gaskets.
low oil pressure could be from what ever other fluids have been mixing with the oil
may need a rebuild.
Old July 12th, 2009, 09:35 PM   #33
96 Boosted GT
may need a rebuild.
BLOWN HEAD GASKET??? theres no blown head gaskets on the car i dont think...the oil is fine it doesnt have any water in it...there hasnt been anything mixing with my oil....
Old July 12th, 2009, 09:42 PM   #34
89Domindart's Avatar
89mustanglx5.0
89Domindart is on a distinguished road
Send a message via AIM to 89Domindart
Looks nice man!!!! I dont think the blue wheels look all that bad.
http://i31.photobucket.com/albums/c390/Domindart/My%20Mustang/DSC00039-1.jpg
89 5.0 for sale! in the classifieds section
Old July 12th, 2009, 09:51 PM   #35
96 Boosted GT
thanks man...and i love the color of your car...
I OPEN UP ANOTHER TREAD ON MY COMPRESSION TEST AND PROBLEMS....!!!
Old July 13th, 2009, 01:25 AM   #36
ryans88gt's Avatar
You have a blown head gasket or cracked head.
Compression test results and rust on the plug make it clear as day.
Throw the autolite 26s in there and you even know the cause of the blown head gasket.
Old July 13th, 2009, 01:41 AM   #37
96 Boosted GT
so im gonna pick up some stock e7 heads tomorrow and throw on some mls head gaskets...you think that will solve the problem???
Old July 13th, 2009, 01:44 AM   #38
96 Boosted GT
maybe a dumb question but if i have a blown head gasket or head y are my fluids not mixing with my oil??
Old July 13th, 2009, 01:45 AM   #39
ryans88gt's Avatar
Skip the MLS gaskets. You need to machine the block and heads to a very smooth RMA or you will have more leaks with the MLS.
The gasket you want is the fel-pro 9333pt1
it is the best gasket for boosted 302 motors dollar for dollar and will take some serious abuse, but still give before the pistons do.
Old July 13th, 2009, 07:56 PM   #40
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
That doesn't mean anything. You don't always have water in the oil with a blown head gasket.
Threads Similar to: got a foxbody notch...yay!!!
Which Foxbody is #1 Speedstang302 5.0 Mustangs 58 February 8th, 2012 05:59 PM
my new foxbody forcefedfox 5.0 Mustangs 13 June 12th, 2009 01:48 PM
A/c on 93 foxbody sctravis77 5.0 Mustangs 2 March 6th, 2009 08:39 PM
90 foxbody 1990gtfreak 5.0 Mustangs 7 June 3rd, 2007 01:02 AM
