cam install problems
I just installed a steeda #19 cam in my combo but im having problems with the set up......
i have a nasty miss fire under load and no break petel at times( lack of vacum i think) and a bad idel (thinking its because of the miss) any ideas? Ps. i put it in dot to dot. thanks in advance.
94gt (Teal) ported gt40x heads, Port matched eddy intake,Steeda #19cam, 1.7 ratio rocker arms, 4.10 rears, 30lb injectors with c&l mass air, 75mm t-body, 190 fuel pump, And a NOS big shot system (100 shot jetting) |
1987 ford mustang gt
well see when shes done
just a question but you did set the valve lash didnt you..
1990 LX hatch
Not being a dick, but did you put your plug wires bak in the right order.
Four things come to mind right away....retarded cam timing, retarded ignition timing, valve adjustment and/or wrong firing order.
Update..
i triple checked the plug wires and they all were in the right place. The timing i have set to 14 degrees base. i don't think that would be to low. i double checked the valve lash to day and that checked out. i have petelsal mounts so i have them all shimed as to not hang open any valves. As for the cam timing im 99.9% sure its dot to dot unless i was seeing things when i closed it up. now i was hoping for a few more sugestions before i second guess myself and tear off the timing cover ect.....
#6 | |
Also, when did the problem start? Right after the cam install?
1993 5.ohhhh
12.97 @140mph
Its far off, but my car ran similar to that when I had a ocuple loose plugs, it just had no compression. I tightened them up and it was good to go.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
Threads Similar to: cam install problems
| Cam install | usafimj | 2005 - 2010 | 35 | March 4th, 2010 07:01 PM |
| cam install | chickenbot | 5.0 Mustangs | 11 | March 5th, 2009 09:57 PM |
| CAM Install | MineralGreyGT | 99-04 | 50 | February 9th, 2009 08:55 PM |
| cam install | spike spiegel | 99-04 | 8 | December 26th, 2008 12:36 AM |
| Cam install ?'s | pfcbrook | 99-04 | 12 | February 29th, 2008 09:11 PM |
