cylinder heads...
i have a question...i am running a b303 cam. i am going to go with afr heads, my question was, how can i be sure that i will have piston to valve clearance....i mean, before i buy the heads, where can i find if the cam will allow me to use the heads?
You need to check valve to piston clearance with the new heads and the cam you will be using. Every engine is different due to machining tolerances and other variables. Two identical engines with the same heads and cam can (and probably will) have two different measurements for valve to piston clearance.
I also wouldn't use a B303 cam. If you are going to spend the money on good heads, spend the money on a good cam.
If a B303 isnt a good cam then what do you recommend?
if the piston does not clear the valves, how do you fix the problem??
#5 | |
#6 | |
Threads Similar to: cylinder heads...
| Cylinder Heads | cbrown | 99-04 | 6 | September 6th, 2007 08:49 PM |
| RHS heads , are they good cylinder heads? | hitorx | 5.0 Mustangs | 25 | May 12th, 2007 10:55 PM |
| SSM cylinder heads for 4.0L V6 | DaemonJ | V6 Mustangs | 6 | March 21st, 2007 12:02 PM |
| Cylinder Heads | thewayshemoves | 99-04 | 7 | December 26th, 2006 08:35 PM |
