whats the normal idle?
Old June 28th, 2009, 02:31 PM   #1
aka Nature boy
sickfox's Avatar
blk 89/red 91 XJ Limited
I like turtles
sickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant future
On my 89 gt it idles at say 900 rpm then after a few minutes it goes to 1000 is that normal, i like it better at 900 it has a good sound to it but when it goes p it sounds like a deep bass which aint bad but just wondering if its normal. my exhuast is ford motorports 1 5/8 equal length shorty headers, flowmaster american thunder exhaust (turndowns after muffler before axle) no cats. any input will be nice on if thats normal or if i need to change the ips or?..
Black Stang Crew Founder #-1
MM+Cleavage Club #15
www.xjor.org
I would drag my dick through a mile of broken glass just to hear her fart through a walkie talkie
Old June 28th, 2009, 02:33 PM   #2
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
Do you have the factory tach?
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old June 28th, 2009, 02:37 PM   #3
aka Nature boy
sickfox's Avatar
I like turtles
unfortunately i have all the factory gauges :'( my amp lights always on and low coolent also. but its charging and full of coolent. so ha yeah i should get new ones.
www.xjor.org
Old June 28th, 2009, 02:44 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Your factory tach is wrong.
Old June 28th, 2009, 02:45 PM   #5
aka Nature boy
sickfox's Avatar
I like turtles
ok great, now lets try this. whats it the answer to the question i asked.
www.xjor.org
Old June 28th, 2009, 02:57 PM   #6
83 5.0's Avatar
83 5.0 is on a distinguished road
Check the sticky's for idle setting, I,m not sure what the base idle RPM is actually as my car is carbed and I keep it around 700 rpm.
Mustang idle surge and base idle reset
These links might help with your wirirng issues with the dash lights, Good Luck
Mustang FAQ - Engine Information
Old June 28th, 2009, 03:13 PM   #7
aka Nature boy
sickfox's Avatar
I like turtles
thank you for that information. its good to get useful info!
www.xjor.org
Old June 28th, 2009, 03:16 PM   #8
aka Nature boy
sickfox's Avatar
I like turtles
answered without answering thanks that sticky in good piece of info.
www.xjor.org
Old June 28th, 2009, 03:35 PM   #9
1993 5.ohhhh
12.97 @140mph
Like darrel said, along iwht what I was going to get at. It's wrong. My tach idles at 400-500, with a timing light on it shows a solid 750 rpm idle.
Old June 28th, 2009, 05:23 PM   #10
83 5.0's Avatar
No Problem, if we all share a bit of what we know somethings got to work.
Old June 28th, 2009, 09:38 PM   #11
aka Nature boy
sickfox's Avatar
I like turtles
so even with an aftermarket tach it will be wrong?? and what tach do you all suggest?
www.xjor.org
Old June 28th, 2009, 09:41 PM   #12
aka Nature boy
sickfox's Avatar
I like turtles
true story man! i like to learn new things, i didn't pop out of my mother with knowing everything mustang like some did. (altho i wish i did)
www.xjor.org
Old June 28th, 2009, 09:54 PM   #13
1993 5.ohhhh
12.97 @140mph
No, just factory.
Old June 28th, 2009, 10:08 PM   #14
aka Nature boy
sickfox's Avatar
I like turtles
No, just factory.
ok i already new that, lets forget i even have one... i can tell by my motor that my car idles low then higher after a few minutes or if i get on the highway when i get off it has an even higher idle and it wont go below that base idle.
i just bought the car, it sat for 4 years. its new i want to know where to start or where to look first.
www.xjor.org
Old June 28th, 2009, 10:20 PM   #15
baine21225's Avatar
get an aftermarket tack for starters, autometer is nice
Old June 28th, 2009, 10:35 PM   #16
Chris951's Avatar
1991 mustang 5.0
Chris951 is on a distinguished road
My factory tach says about 750. I hooked up an aftermarket tach and it read 650. Mine idles at 650..
Old June 28th, 2009, 10:47 PM   #17
baine21225's Avatar
at some spots in the rev range my stocker is about 800 rpms off......pretty substancial difference if you ask me
Old June 28th, 2009, 10:48 PM   #18
1986 mustang gt
1fst5.0 is on a distinguished road
is it normal for your idle to drop a little when u push the clutch in?
Old June 28th, 2009, 11:46 PM   #19
aka Nature boy
sickfox's Avatar
I like turtles
ok im just gonna get an autometer tach, its simple enough. but i still am wondering why my idle is staying high when i get off highway. or why it even jumps up when im at idle. just a bad tps?
www.xjor.org
Old June 29th, 2009, 12:02 AM   #20
Chris951's Avatar
1991 mustang 5.0
clean the IAC, Throttle body, set TPS voltage. See if that works. Mine did the same as yours and I did those things and it never fixed it. Then I saw darrell's sticky and tried the salt and pepper shaker connecter thing and it solved my idle problems.
Threads Similar to: whats the normal idle?
whats the normal temp gauge reading? 03snakeminated 4V / SVT 4 September 2nd, 2008 11:43 AM
Aftermarket TB/Plenum hanging idle/low idle issues! Novanutcase 99-04 12 August 13th, 2008 11:24 AM
(04 Mach I) Normal Warm Idle oil pressure? NewSchool 4V / SVT 1 July 14th, 2008 07:34 PM
1991 Mustang GT Normal Idle 1500rpm? chozenfew805 5.0 Mustangs 5 November 23rd, 2007 08:39 PM
Idle Problems Code 1506, Idle Overspeed Error jagstang96 96-98 3 August 29th, 2006 04:11 AM
