motor knocking - Page 2
Old July 4th, 2009, 12:44 AM   #21
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by 87gtmustang View Post
how do you pull the fuel rails
They come right off. You need the correct tool to get the lines off the rails though.
Old July 4th, 2009, 01:35 AM   #22
87gtmustang's Avatar
1987 mustang GT
87gtmustang is on a distinguished road
Send a message via MSN to 87gtmustang
yeah i figured that out about 20 something mins ago lol. im just hopping it is bc i dont wanna pull the hole motor out
5.0, steeda short shifter, edelbrock intake upper and lower, bbk cold air intake, 3.73, b303 cam, 65 mm throttle body, 65mm mass air, 24 lbs injectors, h pipe, dual flows dump
and more to come
Old July 4th, 2009, 01:37 AM   #23
1987 mustang GT
o and there was about two rocker arms the i could move a little but not much
and more to come
Old July 4th, 2009, 02:30 AM   #24
1987 mustang GT
should i also get new valve steam seals while i got the engine the way it is. my car is burning oil to
and more to come
Old July 5th, 2009, 11:40 AM   #25
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I wouldn't waste the time on valve seals unless you are going to pull the heads off and have them rebuilt. You won't know if the oil burning problem is seals or valve guides or something else without pulling the heads apart.
Old July 7th, 2009, 02:16 AM   #26
1987 mustang GT
the lifters and rods looked good so i guess the next step is to pull the motor and look to see if it spun a bearing
and more to come
Threads Similar to: motor knocking
Rod knocking, motor shopping. C0BRAK1LL3R 99-04 14 May 19th, 2009 04:47 PM
motor knocking 87gtmustang 5.0 Mustangs 26 April 22nd, 2009 02:07 PM
Bad things...Motor Knocking SteviGX 99-04 3 October 9th, 2008 01:31 AM
1997 Cobra Motor knocking........ 1stcobra 96-98 17 March 15th, 2007 09:15 PM
Motor knocking :( ricer_slayer 5.0 Mustangs 5 February 26th, 2007 02:12 AM
