Discussing motor knocking in the 5.0 Mustangs Forum. the motor is knocking and its coming from the valvetrain is there any way to ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1987 mustang GT
motor knocking
the motor is knocking and its coming from the valvetrain is there any way to tell whats making it knock for sure. i dont wanna pull apart the motor right now just to find out then order the parts. i rather order then pull apart. im pretty sure its a lifter but my be a push rod.
if its a lifter what kind of lifters should i buy
5.0, steeda short shifter, edelbrock intake upper and lower, bbk cold air intake, 3.73, b303 cam, 65 mm throttle body, 65mm mass air, 24 lbs injectors, h pipe, dual flows dump and more to come
How are you going to fugure it out with out pulling it apart....You going to call ms Cleo?
"Velocity is better than over all air flow." PeteAndersonRacing.com |
1997 Mustang GT
335rwhp/370rwtq
i doubt knocking would be a lifter, if it were a lifter it would be in the ticking section IMO
2000 gt
some people confuse a knock for a tick. i doubt it's rod knock if it's coming from up top. if it's a "tick" then it's likely a lifter or a header leak.
Procharged 2000 5 Speed BAB GT, 7.3 lbs, 368 hp, 406 rwtq.HARDCORE CREW |
1987 mustang GT
well thats y i was asking idk sometimes theres a trick i may not know or something
i had a header leak before but this is diff
1997 Mustang GT
335rwhp/370rwtq
+1 knocking would be the sound pistons/rods make
2000 gt
a knock will be a deeper sound down in the block. listen from the bottom and see if you can tell. it's hard for me to say over the internet. any way you can post a good vid of it???
14.20@100.62
You mighta spun a bearing... i'm pretty sure thats what this is.
1987 mustang GT
a little throtle
14.20@100.62
Yeah, my friends car spun a bearing and sounded just like that.
1994 Ford Mustang GT
hmm sounds like a tick/knock almost lol
![]() My Daily Driver |
1993 5.ohhhh
14.47 at 96 mph
Piston slap, got the volume down the women is watching tyra banks so I can't hear to well.
exploder top end with 12 psi of v-tech
yeah, um def in the valve train, either collapsed lifter, bent pushrod or broke a rocker off the pedestal. just pull the valve covers, no big deal and the prob should be stairing you right in the face
1989coupe 419w/c4/2 stages of the smack faster than you faster than your first sexual experience |
1987 mustang GT
ok i pulled the intake and the valve covers so far the driver side lifters seem to be ok i havnt checked the passanger side yet got to lake and i couldnt get a bolt off so tomorrow after work ill check the passanger side and if thats good to then ill check the rods
1993 5.ohhhh
14.47 at 96 mph
Huh, huh? There both in the valley of the motor, how could u see one side and not the other?
I'm guessing you mean you didn't take the rockers off on the passenger side to pull the pushrods off, so you can take out the lifters?
How you checkin the rods? Pullin the motor all apart?
1987 mustang GT
kind of but not completely
So how....pullin rod bearings?
1987 mustang GT
how do you pull the fuel rails
Zippee is my step sister.
1990 Mustang LX
9.36@143 mph
It sounds like a valvetrain noise like a loose rocker arm, broken valve spring or bad lifter BUT that doesn't mean it is in the valvetrain. I destroyed a rod bearing once that sounded like a loose rocker. I swore the noise was in the valvetrain, it sounded like it was under the valve cover. I was even going to make another pass with it but decided to go the safe route. If you don't find anything out of place in the valvetrain, you are going to have to pull the engine out and pull it apart.
Thanks to: Trick Flow, Team Z Motorsports, Total Engine Airflow and Furo Racecraft My daily driver has 16 cylinders and 4400hp @ 1000 rpm....
Threads Similar to: motor knocking
| Rod knocking, motor shopping. | C0BRAK1LL3R | 99-04 | 14 | May 19th, 2009 04:47 PM |
| motor knocking | 87gtmustang | 5.0 Mustangs | 26 | April 22nd, 2009 02:07 PM |
| Bad things...Motor Knocking | SteviGX | 99-04 | 3 | October 9th, 2008 01:31 AM |
| 1997 Cobra Motor knocking........ | 1stcobra | 96-98 | 17 | March 15th, 2007 09:15 PM |
| Motor knocking :( | ricer_slayer | 5.0 Mustangs | 5 | February 26th, 2007 02:12 AM |
