1995 Mustang GT
unknown
this sucks, leaking tranny fluid
Started out with a little trip up the interstate, now the car is modified with full bolt ons, but it handled the trip just fine. It was about an hour drive each way. Well, while in the town I visited, I let someone try the car out. He could not drive a stick to save his life, and he was revving the hell out of it and riding it second gear way up in the rpm band. He stalled on take off, said the clutch was too stiff(centerforce,LOL). Well, after getting home, I decide I am going to fix my air conditioning. I get it done and and noticed there was liquid under the car leaking. I put it on ramps and see its tranny fluid from the front of the tranny all the way to the back of the car, I'm quessing it was leaking on the trip and blowing back and possibly from this idiot who couldnt drive. Its a 5 speed car, I am going to have to clean it to see where its coming from. Any trouble spots on these trannies I should look for, I am hoping it was just a line that came loose.
1994 Ford Mustang GT
well if you do get it fixed i would suggest to not let people that have no clue how to drive stick drive your car lol
www.moddedmustangs.com |
1981 4 EYED FREAK
9.48@147
there is a seal in the fron bearing retainer, but i have never seen one leak.. that sounds kinda weird..
![]() www.rodeheavershotrod.com 9.48@147 on pump gas through the mufflers, still has pw,tilt,t-tops,all lights, wipers!!! , check out the vidhttp://www.youtube.com/watch?v=SloE3Zdetac |
#4 | |
1995 Mustang GT
unknown
1993 5.ohhhh
12.97 @140mph
Check the speed sensor on the tranny, mine was a tad loose and I leaked fluid for a LOOOONNNG time.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
#6 | ||
I'm assuming you know the difference between ATF and motor oil but sometimes the PCV, lower manifold, valve covers can leak and it run down the bell housing to the transmission as well.
1995 Mustang GT
unknown
I cleaned it today, I will get under there tommorow and see if I see anything. It appears to be on the right side of the trans (as if your sitting in the car). All of the fluid was concentrated on the right side, it was all over the exhaust, good thing it didnt light up.LOL. What years trannies fit this car(95), if the case is cracked or something I will have to get another one.
you should be able to tell if the case is cracked... unless its now warpped and pushing out the seal
Newblet
1987 GT
This sucks...my brother did the same thing. He let one of his friends drive his car (his friend said he could drive stick) and the guy tried to start a burnout from a dead stop in 2nd gear and burned the clutch up.
It's a lesson learned for everyone...don't let ANYONE else drive your car unless it is family and you are 100% they can drive stick |
1995 Mustang GT
unknown
Well, crawled under there and didnt see where it was coming from. There was a little residue here and there, I noticed one of the lower mounting bolts had a crack around it, but it didnt appear to be leaking from there. I am just going to have to drive it and see if I get anymore leaks.
The Big Spoon
88 5.0 5 Speed Notch <><
never fast enough
bro, make sure that you top it off first. it may not leak anymore because it is empty
1995 Mustang GT
unknown
The Big Spoon
never fast enough
yes
1995 Mustang GT
unknown
well, it appears to be a front seal. After letting it sit a couple days, I see the fluid is draining between the tranny and the bell housing.
The Big Spoon
never fast enough
bummer, while you are in there, install a steel bearing retainer if it hasn't been done already.
Looks like this: Ford Racing M-7050-A - Ford Racing T-5 Bearing Retainers – SummitRacing.com |
1995 Mustang GT
unknown
I cant get to it for a few weeks. I am thinking of just pulling the engine and tranny and redoing some stuff, and while it is out paint the car black.
1995 Mustang GT
unknown
How much does the 5 speed weigh without the bellhousing?
Threads Similar to: this sucks, leaking tranny fluid
| what tranny fluid? | Bandit | 2005 - 2010 V6 | 4 | April 28th, 2008 04:45 PM |
| Tranny Fluid | armymike63b | 99-04 | 7 | November 12th, 2007 11:27 PM |
| tranny fluid | 96gtponyred | 96-98 | 4 | August 8th, 2007 05:49 PM |
| leaking differential fluid | cobralini | 5.0 Mustangs | 4 | May 21st, 2007 02:35 PM |
| tranny fluid | Mustang RacR94 | V6 Mustangs | 1 | April 29th, 2007 11:18 PM |
