wiring diagram for a taurus 2 speed fan, relay, temp sensor
just curious weather anyone has a good wiring diagram on wiring up a 2 speed fan on a relay and temp sensor.
i would like to have the low speed wired to turn on when the temp sensor sets ground, and then have a switch for the high speed. let me know thanks. |
what no one?.....am i the only one who refuses to hook it to a switch?
1989 LX coupe
best setup i seen and what i use with zero problems daily was just using the new heavy duty flex a lite controller pn#33054 wired up to the high speed wire using a 40amp maxi fuse with holder. you would need to use alot of relays to do that. you cant have power going to both high and low speed wires at the same time or it will fry the motor. im sure people have done it but the flex-a-lite controller has a manual override plug you wire to a switch with full adjustment...its a beautiful piece for the money. led indicators and all
i have pics of my install if you need |
#4 | |
Threads Similar to: wiring diagram for a taurus 2 speed fan, relay, temp sensor
| Taurus fan relay | 1989Gt. | 5.0 Mustangs | 8 | June 24th, 2009 04:03 PM |
| went and bought a taurus fan... | mxnate116 | 5.0 Mustangs | 12 | May 10th, 2008 01:39 AM |
| Taurus fan vs Mark vlll fan | black88 | 5.0 Mustangs | 1 | September 20th, 2007 08:57 PM |
| Taurus/Sable fan for a 5.0? | BlueOval | 5.0 Mustangs | 3 | July 30th, 2007 07:27 AM |
