need help head/intake install - Page 5
LinkBack (5) Thread Tools
Old July 21st, 2009, 10:22 PM   #81
stfudvs's Avatar
302 5.0
stfudvs is on a distinguished road
Originally Posted by 1slo5.0 View Post
Also, I don't know why people think a race engine can't be driven at any speed besides wide open throttle. Any engine that doesn't function normally at all rpm is either a piss poor combination or is way out of tune. The only reason most people don't put race engines on the street is because of wear and tear on the parts. The parts are expensive and most people don't want to put anymore wear on them than necessary. Other than that, most "race engines" are totally streetable. My black car made 742hp and ran 9.30s. It made power all over the place and I drove it everywhere. It ran great at 2000 rpm and it ran great at 7000 rpm. Idle, part throttle, wide open throttle.......didn't matter. It ran great in heavy city traffic as well as cruising down the freeway at 70mph. It had sewer sized ports and a big solid roller and 3 1/2" exhaust that everyone says is too big and kills torque
what about us who have to pass emissions, i see a lot of race parts that will not allow me to pass emissions
if people keep arguing when i post questions i may just start pm'ing you and mustank with all my questions
if you were on a bicycle and we were going up hill i could beat you in a race
Old July 21st, 2009, 10:33 PM   #82
stfudvs's Avatar
302 5.0
Originally Posted by superbean View Post
Well luckily many many people run a tride and true twisted wedge setup and it will make the power you want. Keep this thread updated !
well i plan to do my install all at once, so it will be over winter
and i have to accumulate all the parts first
what i will be doing;
twisted wedge heads and custom cam from mustank
i think the intake now is between systemax 2, victor efi super, or trickflow i i i am leaning twards trickflow box
24# injectors
80mm maf/throttle body tb spacer and c&l 4" cold air
new distributer / cap / roter
new radiator, electric fans, and water pump (probably electric)
possible a chip with a tune, havent decided fully on that
new long tube headers and 3" mid pipes to go with it
new 100amp or 140amp altenator
ac delete, with power steering relocator
3.73 gears, short shifter
a lot of this stuff i already have in boxes in my storage
but i will have all the work start once the snow falls in a few more months
i will put up befor and after pictures definitely, and i will do a befor and after dyno
will probably be posting a lot of "opinion" post before buying parts, want to only do this once so want to buy parts that are known to work well and combos that are proven to work
cant wait tell feb/mar of 2010 my car will be a whole new beast
then i can start saving up for body parts and paint
Old July 21st, 2009, 10:47 PM   #83
1998 Cobra
13.24@105.66
I think with a quality 24 lb calibrated maf, the tune wont be necessary. Playing with fuel pressure should be adequate.
weeee foooord!
Old July 21st, 2009, 11:46 PM   #84
baine21225's Avatar
I think i'd use some 30# injectors just for some room to grow, and a chip and dyno is great for a baseline to track tune from......there is some good info in here, dont know how i missed it?
"Whip out your dick you'll either get it sucked or get smacked..."
Old July 22nd, 2009, 12:59 AM   #85
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
That's what I like to hear. Why build a car if you can't drive it on the street?
But yes, constantly spinning a car to 7k rpm does wear out a lot of expensive parts..
Exactly my thinking. I'll never own a car I can't drive on the street.....daily.
The rpm isn't what necessarily wrecks the parts. There are plenty of factory engines that have 7000+ rpm peaks. A more common issue is valve spring wear. Big solid roller cams and high spring pressures combined with alot of street driving will wear out valve springs quicker than just racing on the weekends. I replaced valve springs in my black car 2-3 times a year as routine maintenence. I didn't have a problem with that because I wanted a fast street car and wanted to show the world that you could daily drive a car of that caliber. I wish I wouldn't have sold it......
Old July 22nd, 2009, 01:04 AM   #86
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
If you have to pass emissions, then you have to pick parts carefully. I can't offer much help there because I've never tried to go fast and pass emissions.
Old July 22nd, 2009, 01:16 AM   #87
1998 Cobra
13.24@105.66
If your building an emissions car, pick parts with a carb number and then spray it. Take the bottle off for inspection, very easy..
weeee foooord!
Old July 22nd, 2009, 01:57 AM   #88
Here's another scenario that I have experience with. 347, pump gas, TFS R-series heads, custom solid roller, Trick Flow box intake and 2" primary headers with 3 1/2" collectors and 3 1/2" exhaust. Now based on the bigger equals high rpm power theory this engine should be a turd down low, right? Big runners, big headers, big solid cam, big box intake and small cubic inch should make for no low end power, right? This set up made 423rwhp at 6100 rpm and 403rwtq at 4500 rpm. It had power all over the place. This is totally untuned as well. No chip, no timing or fuel pressure changes either. This was a single baseline dyno pull. The timing and fuel pressure was done off the dyno which is another topic that will probably open up a new can of worms with the dyno lovers.
A stroked motor is a complete different animal then a stocker when talking about long vs short runner intake choices wouldn't you agree?
I understand what your saying, there's tons of bs out there on the net and shit published in mmff but from what I have seen first hand. Throwing a box intake on a stock motor is a waste of money.
Originally Posted by econobarn View Post
Hi, I'm econobarn. This is my first post. I drive a 17 second 4 banger chevy pickup that traps at 81mph and I'm tired of misinformation and stupid on the internet.
Anyone who is debating with 1slo5.0 and 93mustank on this issue really needs to go back to the drawing boards and re-learn engine theory. How is inhibiting flow in any fashion going to create power? It can't unless you live in imagination land. Do you live in imagination land, flyin ryan?
LOL if I lived in imagination land i'd prob be proud to say that I drive a 17 second pickup and have mastered graphing/plotting
Viscosity
to original poster.. if you run the box intake be sure to contact who ever made your cam and see what they suggest you using to maximize your combo.
Old July 22nd, 2009, 02:06 AM   #89
stfudvs's Avatar
302 5.0
i have never used nos befor, i have heard its bad for your car, and scares me
i thought about turbo, but decided for now i want n/a power
was thinking about the 30#ers but wasnt sure if it was practical or excessive
should uprade my driveline/draveshaft, im worried that with my 20 year old stock car adding all this stuff at once i would romp on it and likley kill them, or my transmission
thoughts ?
Old July 22nd, 2009, 02:06 AM   #90
Flyin ryan will you post up some of your all motor combos along with 1/4 times? Thanks
PeteAndersonRacing.com
Old July 22nd, 2009, 02:07 AM   #91
thoughts ?
If you need info you can pm me.....weird....I have owned these parts.........
Old July 22nd, 2009, 02:09 AM   #92
stfudvs's Avatar
302 5.0
seeing my combo do you think it will be a waste or give me a good power range?
Old July 22nd, 2009, 02:17 AM   #93
stfudvs's Avatar
302 5.0
Originally Posted by 93mustank View Post
.Beat a Z06 the other day.
legit
Old July 22nd, 2009, 04:18 AM   #94
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
So if it was a 351W then it would be a bad choice but on a stroked 302 it is a good choice? If the engine was a 302 with the same cam, heads, compression and headers I still would have used the box intake and it would have made enough power that people would have swore it was stroked.
Nobody is talking about using a box intake on a stock engine.
Old July 22nd, 2009, 04:19 AM   #95
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Power adder combos too. List all of them. Maybe we all should.
Old July 22nd, 2009, 10:25 AM   #96
baine21225's Avatar
Can I post daddy's cars times? . . . . I drive it at the track occasionally, so that counts right?
Old July 22nd, 2009, 01:20 PM   #97
haha I've been bugging you for info and haven't seen chit but now I have to put out
It all comes down to what cam you run with those heads/box.. I've seen people throw a box intake on a car that previously was setup for a long runner intake and they weren't happy with where the power band was for dd street use. Which is all i've been trying to say.
I think that's a good idea, start a thread and i'll post in that when I can but not in this guys thread. It'll only drag this pissing match on even longer
Old July 22nd, 2009, 01:35 PM   #98
Slowmobile
17.1@81
econobarn has a little shameless behaviour in the past
...I guess flyin ryan really does live in imagination land.
Old July 22nd, 2009, 01:54 PM   #99
1998 Cobra
13.24@105.66
thoughts ?
Nitrous is only bad if it is used incorrectly. Key to a nitrous setup is not to cheap out when setting it up.
Most Wet systems will work with only a timing change. Example.. running a 75 wet shot, it will provide fuel as well as no2. To run a small shot like a 75, just throw a timing light on the motor and pull 2 or 3 degees of timing and run good gas.
Factory pistons will handle the abuse just fine.. the block will prob split before the bottom end lets go.
Now slapping a 200 dry shot on a stock motor with no timing changings is a good way to put a few holes in some pistons.
If your interested I have a complete dry kit. Jetted for a 75 shot, has fogger nozzle, braided 15 ft line, 10 lb brand new NOS brand bottle (half full still), nitrous solenoid, and wot switch with wiring. I'll let it go cheap to a MM member. This kit can be converted to a wet system for the cost of the fuel line and fuel solenoid (<100 bucks)
weeee foooord!
Old July 22nd, 2009, 02:03 PM   #100
stfudvs's Avatar
302 5.0
good offer but to much going on at the moment to think about nos
i have thought about it, 75 wet at wot seems to be along the line of what i would do
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/128916-need-help-head-intake-install.html
MidSouth Drag Racing • View topic - Another Stupid Colorado Drivers thread. 225cc AFR's on a 5.3 This thread Refback February 18th, 2010 11:17 PM
MidSouth Drag Racing • View topic - Another Stupid Colorado Drivers thread. 225cc AFR's on a 5.3 This thread Refback July 23rd, 2009 12:08 PM
MidSouth Drag Racing • View topic - Another Stupid Colorado Drivers thread. 225cc AFR's on a 5.3 This thread Refback July 22nd, 2009 06:13 PM
MidSouth Drag Racing • View topic - Another Stupid Colorado Drivers thread. 225cc AFR's on a 5.3 This thread Refback July 22nd, 2009 04:57 PM
5.3L with new TFS 205 heads - Page 5 - 355Nation Chevy Colorado & GMC Canyon Forum This thread Refback July 22nd, 2009 04:01 AM
Threads Similar to: need help head/intake install
head lights install hedgehog 4V / SVT 0 November 8th, 2008 12:53 PM
5.0 need a tune after head and intake install? kid 5.0 Mustangs 17 April 23rd, 2008 01:02 AM
99 head unit install bubagump17 99-04 0 December 4th, 2007 04:02 PM
head unit install (yes another 1) BlackIce Audio/Video 4 February 22nd, 2007 05:34 PM
Need Help With Head Unit Install Teggy_Boy Audio/Video 1 January 18th, 2007 07:54 PM
