LinkBack (5) | Thread Tools |
#121 | |
![]() At least on forced induction cars, the cars will produce more power and torque at 12.5:1-13:1, but cylinder temps will get so high that you will melt pistons, plugs and everything in between. That is why most FI guys waste their time making sure A/Fs stay in the safe zone. With that said, a wideband is only as good as the person comparing the numbers to the spark plugs. A number is just a number. For the other people, runner velocity, runner length, runner cross section, and runner volume all come into play in optimizing torque vs rpm range. There is a lot of complex calculus based math and years of engine design and tuning to back that up. Simply cutting the runner length in half without the corresponding changes in runner cross section and desired rpm range is a sure fire fail. Shorter wider runners are optimized for higher rpm where cylinder filling has to occur at very high speed. Longer narrower runners are more efficient at low speed cylinder filling do to the ram effect of the velocity of the air in the runner. The most efficient intake runner is always the longest runner that does not inhibit air flow at the highest desired rpm.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
#122 | |
make some recomendations
if you were on a bicycle and we were going up hill i could beat you in a race |
#123 | |
#124 |
1990 LX hatch
*cricket noises*
#125 | |
I think I broke the rules with short runner intakes too. I've used them sucessfully without having to turn a million rpm. I must be on to something...
#126 | |
These cars can take a little more detonation then those gm's I've owned but I'd still be pretty leary of that method but we both know you know your shit so rock on |
#127 |
grand national ftw
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
#128 | |
#129 |
.....some of us can't read plugs
#130 |
1990 LX hatch
Plug reading is awsome but it dosent help when you are reading them thru the new holes you just put in your pistons.
J/k
#131 | |
Plus not everyone has access to a track to make passes, pull over and yank plugs and repeat. |
#132 |
anyone wanna do a plug reading seminar?
#133 | |
If you "run the shit out of the car" before you tune it, that's your problem. Nobody makes full WOT passes with an untuned car.....unless they're stupid. I don't think you need to tell me what is important and what is not with racing. I have a little bit of experience and I think my combinations speak for themselves....
#134 | |
PeteAndersonRacing.com |
#135 | |
#136 | |
For the record, I'm no stranger to boosted or nitrous cars. I don't know where you got that from but I have a bit of experience with power adders. ![]() My last daily driver made 562hp to the tires with a 302..... No a/f gauge.
#137 |
1993 5.ohhhh
12.97 @140mph
The plug thing seems like a, oops to late method if your not smart about it. Well good thing widebands are attainable these days. Pulling a plug even with a wideband is still important though.
With my horrid valve spring problems, for some reason my plugs turned african black after I drove it again for the first time. But theres nothing on the wide band but normal readings. My wide band is bunged into the left side of the hpipe before the cross over, so its more on one bank. So far it reads accuratly but it still leaves me a little worried
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
#138 | |
Shouldn't be an issue on the street because who drives around wide open throttle on the street long enough to wreck anything????
#139 | |
1993 5.ohhhh
12.97 @140mph
#140 |
so can someone please explain to me how to read plugs?
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/128916-need-help-head-intake-install.html
| MidSouth Drag Racing • View topic - Another Stupid Colorado Drivers thread. 225cc AFR's on a 5.3 | This thread | Refback | February 18th, 2010 10:17 PM | |
| MidSouth Drag Racing • View topic - Another Stupid Colorado Drivers thread. 225cc AFR's on a 5.3 | This thread | Refback | July 23rd, 2009 11:08 AM | |
| MidSouth Drag Racing • View topic - Another Stupid Colorado Drivers thread. 225cc AFR's on a 5.3 | This thread | Refback | July 22nd, 2009 05:13 PM | |
| MidSouth Drag Racing • View topic - Another Stupid Colorado Drivers thread. 225cc AFR's on a 5.3 | This thread | Refback | July 22nd, 2009 03:57 PM | |
| 5.3L with new TFS 205 heads - Page 5 - 355Nation Chevy Colorado & GMC Canyon Forum | This thread | Refback | July 22nd, 2009 03:01 AM | |
Threads Similar to: need help head/intake install
| head lights install | hedgehog | 4V / SVT | 0 | November 8th, 2008 11:53 AM |
| 5.0 need a tune after head and intake install? | kid | 5.0 Mustangs | 17 | April 23rd, 2008 12:02 AM |
| 99 head unit install | bubagump17 | 99-04 | 0 | December 4th, 2007 03:02 PM |
| head unit install (yes another 1) | BlackIce | Audio/Video | 4 | February 22nd, 2007 04:34 PM |
| Need Help With Head Unit Install | Teggy_Boy | Audio/Video | 1 | January 18th, 2007 06:54 PM |
