Power loss...
Old July 2nd, 2009, 07:50 PM   #1
1sl0w88's Avatar
88 LX 5.0 Convertable
1sl0w88 is on a distinguished road
Power loss...
Ok, I posted another thread about my problems but this one may be different, hence the new thread.
My 88 runs fine until you turn right. When you turn right the damn thing dies. Turn the wheel back to the left and it is back to normal. Cant find anything that may be pinched or shorting out. It wont do it while sitting still tho. Only while driving.
Please guys, any thoughts or ideas?
Robbie
_________________
88 LX Convertible 5.0
84 GT - Project
66 F100
Old July 2nd, 2009, 09:20 PM   #2
JBIGBOOTSY's Avatar
1990 LX hatch
fuel pickup?
Old July 2nd, 2009, 09:33 PM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by JBIGBOOTSY View Post
fuel pickup?
That certainly is a possibility since the fuel will be running away from the pump when you turn right.
Old July 2nd, 2009, 10:06 PM   #4
flamestang's Avatar
flamestang is on a distinguished road
had an explorer do exactly that.installed a pump assembly fixed it.
Old July 2nd, 2009, 10:40 PM   #5
1sl0w88's Avatar
Brand new fuel pump. But it will do it even as I pull up to a stop sign and barely be moving.
Robbie
_________________
84 GT - Project
66 F100
Old July 2nd, 2009, 10:49 PM   #6
1986 mustang gt
1fst5.0 is on a distinguished road
the baffle in your tank has come undone
Old July 2nd, 2009, 11:25 PM   #7
1sl0w88's Avatar
This is more like it is losing power, not fuel. It just dies like you turn it off.
Robbie
_________________
84 GT - Project
66 F100
Old July 2nd, 2009, 11:28 PM   #8
1sl0w88's Avatar
I remember back in the 70's this guy brought his "Cuda" to my dad and grand-dads shop with the same problem. Turned out that it was his coil. It had a short in it. But his would do it while sitting still. I even put another coil on it and it still does it.
Robbie
_________________
84 GT - Project
66 F100
Old July 3rd, 2009, 12:14 AM   #9
Traidmarx's Avatar
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
Traidmarx will become famous soon enoughTraidmarx will become famous soon enough
just an idea and i might be wrong, but could it be the PS pump possibly going bad and causing it to drag on the accesories more?? my friends 89 bronco had a similar problem
1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon.
Old July 3rd, 2009, 12:54 AM   #10
Chris951's Avatar
1991 mustang 5.0
Chris951 is on a distinguished road
Yeah, my PS pump is going bad and if I turn the wheel while going through a parking lot or something my rpms drop
Old July 3rd, 2009, 06:12 PM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
When did this problem start? Before the fuel pump install or after?
Old July 4th, 2009, 12:59 AM   #12
well it has to be either the baffle in the tank or the ps pump is toasted.. so i'd by pass the ps pump with a shorter belt or just take the serp belt off all together and start the car up and quickly take it for a run down the street making sure to do what normally causes the car to die like making your righ hand turn.. if the car doesn't die then it's your ps pump but if it continues i'd prob think it's the baffle that came loose in the tank just my opinion
Old July 4th, 2009, 02:16 AM   #13
1sl0w88's Avatar
With all the other problems I was having Im not 100% sure. But I think its got something to do with the fuel pump. Im going to take it back out to see. I believe something just isnt right and when I make those right turns its pinching the fuel line.
Robbie
_________________
84 GT - Project
66 F100
Old July 4th, 2009, 02:18 AM   #14
1sl0w88's Avatar
I took it to a friend of mine that is a mechanic with Ford and had the whole shop scratching their heads. Now that was funny as shit.
Robbie
_________________
84 GT - Project
66 F100
Old July 4th, 2009, 03:23 AM   #15
I took it to a friend of mine that is a mechanic with Ford and had the whole shop scratching their heads. .
Happens more times than you think...
PeteAndersonRacing.com
Old July 5th, 2009, 11:38 AM   #16
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Yes it does. I used to fix alot of shit from the GM and Ford shops that they couldn't figure out. Funny as hell.
Old July 12th, 2009, 10:21 PM   #17
1sl0w88's Avatar
UPDATE!
Took the tank back down and pulled the fuel pump and assembly out in TWO pieces ! Repaired the assembly and BINGO, it runs fine. I guess the pump was "free swinging" in the tank and when I made those right turns it was pinching off the line.
Robbie
_________________
84 GT - Project
66 F100
Old July 13th, 2009, 12:15 AM   #18
aka Nature boy
sickfox's Avatar
blk 89/red 91 XJ Limited
I like turtles
sickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant future
nice to figure the problem out and have it be something simple! good to hear man!~
Black Stang Crew Founder #-1
MM+Cleavage Club #15
www.xjor.org
I would drag my dick through a mile of broken glass just to hear her fart through a walkie talkie
Threads Similar to: Power loss...
power loss Elder 4V / SVT 8 September 8th, 2008 04:31 AM
power loss 03Gtmustang 99-04 13 September 6th, 2008 01:16 AM
Loss Of Power! Help Please! alamo11 V6 Mustangs 8 December 14th, 2007 09:34 AM
power loss? xedubx 99-04 16 June 20th, 2007 10:52 PM
Power Loss the hammr 5.0 Mustangs 8 August 17th, 2006 09:48 PM
