1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
F or E
i'm doing some research i've searched a few threads trying to get the right information i need, i can get either cam dirt cheap, its going in a DD car so i was gonna do the alphabet cam for now, from what i was reading and i guess correct me if any part of this is wrong. But the F cam makes more top end power so i'm assuming that since i have the 4.30's that the F Cam would help me in the upper rpms to keep the motor pulling longer to make the rpm range more efficient. I don't plan on putting the cam in without the a set of heads and intake. So i was curious what would be the best combo as far as setting that up i'm not looking to spend a ton on the heads and intake. Reason i'm not waiting and spending more on the H/C/I set up is because i'm wanting to get a block and kinda put things together piece by piece over the next year or so. oh and i will also be spraying a 150 shot but the car will be tuned for it. also could i get alway with using 1.7's with this cam or should i stick with 1.6's. Thanks for any advice you guys can give in advance.
![]() 1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon. |
Priest of the Car Gods
If it's going in a DD, wouldn't it be better to chase midrange power instead of top end? My OHC DDs spend >90% of their life under 2300 rpm, the pushrod cars usually under 1800.
O o /¯/______________________ |BLAAAAAAAAAAAAAAAAAAAAAAAAARGH!!! \_\ Buy my Bronco, special deal for MM folks |
#3 | |
1995 Mustang GT
the main problem with the car now is the 4.30's run thru the rpm's so fast i have to short shift the car most of the time just to get it in the power range in the next gear.
![]() 1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon. Last edited by Traidmarx; July 2nd, 2009 at 11:41 PM. |
#4 | |
2000 mustang GT
1995 Mustang GT
yea its def. not winning any MPG awards haha...sad thing is i do mostly highway driving so i'm usually driving at 60-65 mph and around 2700 rpms....
Ah, reading comprehension fail - I didn't realize that the 4.30s were already installed.
#7 | |
aka Nature boy
blk 89/red 91 XJ Limited
I like turtles
1995 Mustang GT
lol yea i've thought about swapping but it seems to pull good i don't mind the bad mpg, its not horrible, i'll give up a lil bit of mpg to make up for performance...plus i got the gears used for $50 and they only had about 1500 miles on them...when the car was wrecked.
#9 | |
aka Nature boy
I like turtles
i see, well i bet it pulls nice. i have 3.73's there good for me but i dont know anything better LOL so im sure its harder to down size. i do have a set of 4.10's i could swap. how much difference would i see?? altho i am happy with a 3.73.
1995 Mustang GT
my friend swapped 3.73's to 4.10's and it felt a lot better...but then again he has a 97 Cobra so he's got more rpms to go through.
#11 | |
aka Nature boy
I like turtles
1993 5.ohhhh
12.97 @140mph
The fcam to me never felt to strong in its advertised rpm range. But then again I was on stock springs, so it never prob worked to it's full potential. I'm just here to remind you to get new springs lol.
I'm about to do a spring swap with the heads on the car this sat.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
1995 Mustang GT
yea def. was gonna do new springs...and hardened push rods,etc.
skip the f cam.
weeee foooord!
1994 Ford Mustang GT
how much are you getting one of these cams for? you can get a custom ground cam from jay for $300 to work best for your set up, just a thought
www.moddedmustangs.com |
1992 Lx
11.39@119.24
steeda #19
Waste of time
PeteAndersonRacing.com |
1993 5.ohhhh
12.97 @140mph
He already acknowledged this thoough.
1995 Mustang GT
i'm not looking to make some crazy unthinkable horsepower with it, just wanted a mild
H/C/I while i took my time and put together something like a 347 with a set good heads and stuff...but anyway thanks for the replies i won't bring it back up.
The Razor's Edge
back in the 80s they called the f cam camzilla lol
