Discussing stroker short blocks? in the 5.0 Mustangs Forum. Originally Posted by flamestang exactly stroked engine is going to may lots more power, not ...
Old July 5th, 2009, 12:30 PM   #21
86er's Avatar
Originally Posted by flamestang View Post
exactly stroked engine is going to may lots more power, not just the block issue rings and bearings as well. my original statement was 331 would last longer than a 347. 347 is almost maxed out for a stock block.
what maxed out about a 3.4 stroke and a 4.030 bored motor???
1989coupe
419w/c4/2 stages of the smack
faster than you
Old July 5th, 2009, 01:02 PM   #22
Zippee is my step sister.
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Exactly. I'm sure we will here things like "rod ratio" and "piston side load" and "wrist pin intersecting the oil ring". I can't wait to learn why a 331 is a better choice than a 347 and I really can't wait to learn why a 347 isn't reliable and why it will burn oil.
Thanks to: Trick Flow, Team Z Motorsports, Total Engine Airflow and Furo Racecraft
Old July 5th, 2009, 01:21 PM   #23
1998 Cobra
13.24@105.66
I've also seen rebuilt 302/306's last maybe 5k miles, and i've seen stroked motors run for years and years of daily abuse.
It's all about how hard you run it and how WELL it's put together.
weeee foooord!
Old July 5th, 2009, 06:01 PM   #24
fs308's Avatar
id love to hear what they would say about the 357's people run. that rod ratio gotta be all fucked up
87 Notch
Doing a lot with a little
_____________________________
lightweight, stock motor, and 12's?
Old July 5th, 2009, 06:43 PM   #25
1998 Cobra
13.24@105.66
lol
weeee foooord!
Old July 5th, 2009, 07:13 PM   #26
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Or how about that 8.2 deck 408 that guy runs in his sprint car on SBF Tech.
Old July 5th, 2009, 08:15 PM   #27
fs308's Avatar
lol i must have missed that one over there. i seen the thread about the guy with the 392 8.2 deck motor
87 Notch
Old July 6th, 2009, 05:01 PM   #28
flamestang's Avatar
1992 mustang gt
10.942@125 / 6.877@103
Originally Posted by 1slo5.0 View Post
Yes it is. This shit cracks me up. If a person doesn't know what he is talking about, he shouldn't be talking....
I have built a hand full of stroker motors and ran with friends, 331 and 347 on street and track.Also Certified Ford gas engine technician. 347 is not an ideal street motor due to rapid wear on the rings (from the relatively low rod ratio) and increased oil burning.331 rod ratio is closer to stock 302 ratio. 331 is a better street engine.Since you don't think I should be talking maybe I should sign off and let you crack yourself up.
1992 GT/347 Paxton 2k C4 478hp 501tq
Old July 6th, 2009, 05:30 PM   #29
1985 Mustang GT
AAAANNNNDDDD their it is
Old July 6th, 2009, 05:40 PM   #30
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I knew the rod ratio bullshit would come up. Hmmm, lets discuss this for a bit. Why is it that rod ratios apply only to the 347 and not to anything else? The Chevy 400 which was used in thousands of cars and trucks over the years and lasts well over 100,000 miles with CAST pistons has a 1.48 rod to stroke ratio. A 347 has a 1.59 rod to stroke ratio. The Ford 5.4L has a 1.59 rod to stroke ratio. The Chevy 454 and the 502 have a 1.53 rod to stroke ratio. Honda 4 cylinders have a 1.58 rod to stroke ratio. The Pontiac 455 has a 1.57 rod to stroke ratio. Toyota makes some of the most reliable engines on the road with 1.57 rod to stroke ratios. A 408 uses a 1.55 rod ratio. Do 408s wear rings out and burn oil too? Rod ratios mean nothing. You can take that to the bank. There is no rapid ring wear in 347s or any of the other engines I listed above. That is 100% bullshit. Show me a 347 that burns oil. That's great if you've built a handful of stroker motors with friends. That doesn't make you an expert in the field. Talking about rod ratios and oil burning confirms that. I've built and owned several handfuls. None of them ever burned a drop of oil and none of them were unreliable. All of them were daily driven. Come to think of it, I've never talked to anyone that has ever had a 347 burn oil or have any issues. But I have run into alot of internet experts that preach this oil burning and rod ratio bullshit.
Old July 6th, 2009, 07:12 PM   #31
93mustank's Avatar
[quote=flamestang;2171061]I have built a hand full of stroker motors and ran with friends, 331 and 347 on street and track.Also Certified Ford gas engine technician. QUOTE]
You built a 347 with a supercharger that runs 11.1 at 125....
Need I say more
“No track close to me, but with my old stock head, E cam setup N/A I was hitting 14 flat at 105 on cheap street tires using a G-tech”
"I want some nice super high flow CAST IRON heads.
PeteAndersonRacing.com
Old July 6th, 2009, 07:21 PM   #32
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Need I say more
LMFAO!!!!!! I missed that.
My supercharged 302 ran 10.6 @ 132....
Damn!
Old July 7th, 2009, 12:01 AM   #33
1993 mustang lx 2.3
havnt ran yet
he must not know how to launch lol speaking of the stroker business im planning on a stroker later down the road but in your opinion which one responds the best to supercharging?
Old July 7th, 2009, 12:03 AM   #34
93mustank's Avatar
Say wa..you serious?
Old July 7th, 2009, 12:10 AM   #35
1993 mustang lx 2.3
havnt ran yet
yeah im serious the 331 may be better supercharged than the 347 of vice versa.
Old July 7th, 2009, 12:15 AM   #36
93mustank's Avatar
What do you think would respond better?
Old July 7th, 2009, 12:21 AM   #37
1993 mustang lx 2.3
havnt ran yet
idk i was thinking a 347 then i saw that one dudes times and was like wow either he built it like shit or its just not the motor to be supercharging thats why im asking you guys from what you say you seem to know your shit.
Old July 7th, 2009, 12:23 AM   #38
93mustank's Avatar
Your first thought was right......
Dont run a 331 when you can run a 347 for the same price.....
The name of the game is money..... but examples out there show otherwise.
Old July 7th, 2009, 12:25 AM   #39
e3sean's Avatar
1988 lx stock block
10.47@128 125shot
ive said it before and ill say it again....
my quote bitches dont steal it as your own!!!
The great E3Sean once said:
The only thing you will be burning when choosing a 347 over a 331 is the guy driving the 331!
my 347 burns no oil and i drive it nearly every day. i drive it an hour across town in 110* weather i drive it down the track 10 passes a night on a 125 shot... no problems...
MILITARY CREW
USAF LUKE AFB AZ,
E-5
Old July 7th, 2009, 12:27 AM   #40
Lind's Avatar
1994 Ford Mustang GT
lol, i just about fell out of the chair
My Daily Driver
Threads Similar to: stroker short blocks?
Best short blocks/rotating assemblies??? silverstang 2005 - 2009 20 January 22nd, 2009 05:06 PM
5.0 stroker short blocks.. adrenaline=lifeline 99-04 2 August 18th, 2008 09:21 PM
short blocks screwed by twins 5.0 Mustangs 7 July 23rd, 2008 08:06 PM
Short stroker, large bore/ Long Stroke, small bore 331STANG 5.0 Mustangs 20 July 23rd, 2008 05:28 PM
Engine Swap: Small Blocks or Big Blocks Speedstang302 5.0 Mustangs 32 April 15th, 2007 10:34 AM
Forum is powered by vBulletin ©2000 - 2010, Jelsoft Ent. Ltd. & SEO by vBSEO 3.3.2 ©2009, Crawlability, Inc.
