problems after 4:10 swap?
Old July 3rd, 2009, 07:37 PM   #1
78mach1's Avatar
78mach1 is on a distinguished road
Send a message via MSN to 78mach1
well i finished up my 4:10 swap. when we were done i measured 8 thousandths of an inch of back lash. and when we painted em and rolled em they looked great. not to shallow not to deep, not to high not to low.
when i am accelerating from about 35, there is a slight hum, and after about 65 there is a slight vibration threw out the whole vehicle, checked drive shaft its tight, checked bolts there tight, i did the u joint a month ago.
what do you think?.....probably going to pull the diff cover and take another look inside.
Old July 3rd, 2009, 09:02 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Gears aren't installed correctly. Pull it apart ASAP before you do permanant damge to the gear set.
Old July 3rd, 2009, 10:28 PM   #3
78mach1's Avatar
ya i parked it tell sunday when i will have time tow work on it.
what would cause the vibration?
Old July 4th, 2009, 12:22 AM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Wrong shims. Its most likely too lose. If it howls on decceleration, it confirms that the clearance is too lose.
Old July 4th, 2009, 04:01 AM   #5
78mach1's Avatar
would that have shown up in the back lash measurement?
mine is howling during acceleration, and makes zero noise during decceleration.
Old July 5th, 2009, 11:36 AM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
It should have been noticed when you meausured.
They aren't used gears, are they?
Old July 5th, 2009, 04:58 PM   #7
78mach1's Avatar
the gears were in seans car for a short time. the teeth werent even shiny yet.
im taking it apart today to check it out.
Old July 6th, 2009, 12:12 AM   #8
The Razor's Edge
White Thunder's Avatar
blame sean! lol jk
founder of the FTN Club
Old July 6th, 2009, 03:15 PM   #9
78mach1's Avatar
Originally Posted by White Thunder View Post
blame sean! lol jk
im considering that lol jk.
no i pull its all apart and rechecked all my measurements, everything looks great, i painted the pinion and rolled it, it couldnt look better.
now is it possibe for the posi to be what is wining?
Old July 6th, 2009, 03:22 PM   #10
e3sean's Avatar
1988 lx
9.68@142
e3sean is a jewel in the roughe3sean is a jewel in the roughe3sean is a jewel in the roughe3sean is a jewel in the rough
they were bran new and set up by a reputable shop in my car and they still had a very low hum to them under acceleration. i herd the richmonds are very touchy when it comes to that but i never had any vibration.. and there was no visable wear at all when i pulled them out. i didnt even have but a few hundo miles on them.
<font size=4><b>MILITARY CREW
Old July 7th, 2009, 01:09 AM   #11
78mach1's Avatar
there is not doubt in my mind that they were used or abused or not installed correctly, they looks great and the teeth looked great!.......i think this small vibration might be something im feeling in my drive line that i never felt before because of my old gearing. im considering buying an aluminum drive shaft.
Old July 7th, 2009, 01:27 PM   #12
1992 Lx
11.39@119.24
blame sean he pee'd on them before they were mailed out
Threads Similar to: problems after 4:10 swap?
Which one is easier??a rear end swap or engine swap? Bies08 V6 Mustangs 42 May 11th, 2010 05:33 PM
PI Swap Problems? 4.6LMadness 96-98 26 March 13th, 2009 10:44 PM
PI swap problems?!? dc1515 96-98 18 June 20th, 2008 04:36 PM
Potential problems/issues with engine swap robz301 V6 Mustangs 22 December 26th, 2007 03:19 AM
HELP!!! PI Swap problems 97gtstang 96-98 5 April 19th, 2007 02:15 AM
