LinkBack (1) | Thread Tools |
#1
1993 5.ohhhh
12.97 @140mph
valve spring locks
Whats the trick to these? I'm practicing swapping valve springs on a spare set of heads in the garage. I have my spring compressor. Before I compress the spring, I put a deep socket on the lock, so it doesn't touch the valve. I tap it with a dead blow with a little bit of force.... then I compress the spring, but it does nothing for the locks. There strong as ever. Any pointers.
And were do you find those damn dentist metal picks. They look like they would pull them out.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
The Razor's Edge
dentist metal picks = a scribe
1993 5.ohhhh
12.97 @140mph
Thank you for that clarification... were can I find these?
The Razor's Edge
i would assume sears - craftsman
1993 5.ohhhh
12.97 @140mph
Great.... I'm sure they are open for the 4th of july. I wonder if home depot or lowes would stock these.
The Razor's Edge
i dunno but it should be a pretty common tool....
You put a socket on the actual lock?....ummm ok not good....Socket should go on the retainer....Then compress
PeteAndersonRacing.com |
Proud American
Yeah, the locks should just fall out once the retainer is pressed down.
1990 Mustang gt
I don't understand why you have a socket in there to begin with. If you have a spring compressor that should be all you need
2002 gt 5-speed 1990 gt 5-speed 1981 Notch Roller |
You have not taken many springs apart have you?
1990 Notch
It's used to just hit the top of the spring to "knock everything loose". The socket isn't used for the actual compressing of the spring.
Chad 1990 Notch 12.9 @ 105 |
1982 GT t-top
no proof of purchase
And were do you find those damn dentist metal picks. They look like they would pull them out.[/QUOTE]
It's called a pick sears sells sets of them.... |
lolz. locks freakin suck! especially in a camaro
Compress with spring compressor, then give it a gentle tap with a dead blow and watch where the locks fly
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
1990 Mustang gt
The only automobile heads I have dissambled are the stockers off my car. I have taken apart alot of honda motorcycle/atv heads. I always just use my spring compressor.
1993 5.ohhhh
12.97 @140mph
I'll try hitting the retainer with a good socket, compress the spring, then hit the locks with a plat head and dead blow tomorrow. Hopefully that works.
I'm practicing on some old e7s on a shelf.
1993 5.ohhhh
12.97 @140mph
Still no luck.... I'm going to put the rope in the engine to hold up the valves and just go ahead and do it on the car I think. I couldn 't even get the locks out with a scrive after they had been hit, and the spring was compressed.
*scribe
"Whip out your dick you'll either get it sucked or get smacked..." "That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
1982 GT t-top
What kind of compressor are u using
1993 5.ohhhh
12.97 @140mph
scrive*
Just a manual twist one.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/129064-valve-spring-locks.html
| valve spring locks | This thread | Pingback | July 4th, 2009 04:37 AM | |
Threads Similar to: valve spring locks
| GT-40P Stock Valve,Locks,&Retainer Size's? | 5.0 street stanger | 5.0 Mustangs | 4 | May 5th, 2009 09:19 PM |
| Valve Spring Kit?? | BoostHard1210 | 99-04 | 11 | February 12th, 2009 10:19 AM |
| Valve Spring Troublee! | tehdwarvenn | 5.0 Mustangs | 12 | September 12th, 2008 08:20 AM |
| Valve spring cups | hooligan | 2.3 Mustangs | 0 | March 31st, 2008 12:57 PM |
| Valve Spring removal | acmillr | 99-04 | 0 | January 7th, 2007 10:53 AM |
