Proper valve springs for E7's with an X-cam?
Old July 4th, 2009, 02:01 PM   #1
1990 Notch
Silversixspeed is on a distinguished road
Without doing enough research, I bought Comp Cams 986-16 double beehive springs, and didn't realize the heads would need a little machining for these to work, so now I'm back to square one.
Whats a good, no machinework required, stronger valvespring that'll work in my E7's, and handle an X-cam?
Old July 5th, 2009, 12:15 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Does it have a spring recomendation on the cam card? If not, call Ford Racing and see what they recommend for a spring.
Why an X cam?
Old July 5th, 2009, 02:01 PM   #3
1998 Cobra
13.24@105.66
that's a lot of cam for stock heads.
weeee foooord!
Old July 5th, 2009, 05:12 PM   #4
1990 Notch
Why an X cam?
I planned on GT-40's originally, but had things come up and I couldn't quite scrounge up the money for them. Instead I got a free set of E7's, and have been porting them myself over the last couple weeks. I know it's too much cam for the heads, but I'm planning to build the stock motor thats in my car as a 347 over next winter, while these heads and cam will go into the recently rebuilt roller shortblock I have in the garage.
Somebody recommended these.. They say they are good to .520 lift, but the X-cam is .542. Are they "good enough"?
Chad
1990 Notch
12.9 @ 105
Old July 5th, 2009, 06:20 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
That cam is 20 year old technology and won't be impressive at all. In a 347 it won't be right either. You'd be better off putting heads and intake and the correct cam in a 302.
Valve springs are either correct or incorrect, and never good enough. If you use a .542 lift cam with springs that are only good for .520 lift, you will end up with a pile of broken junk.
Old July 5th, 2009, 06:30 PM   #6
1998 Cobra
13.24@105.66
X cam is too big for gt40 heads.
When building a stroker, there are too many variables... bore and storke, cid, what heads, what compression, what kind of exhaust, driveablility, track or street use, what gear your running, auto or stick.... only one way to make the cam work for you...
I'll let Darrell tell you what he thinks about custom cams.
weeee foooord!
Old July 5th, 2009, 06:58 PM   #7
1990 Notch
Not sure if this makes a difference, but the car is carbed, is my "daily driver" on nice days, manual, and streetability isn't a huge issue for me. I only drive about 7 miles total round trip in a day. I'm also spraying a 100 shot, and will hopefully bump it to 125 or 150 with this other motor.
So, would I be best off getting a different cam? I'd like something that'll work for these E7's (too big doesn't bother me much), and something that'd work well with GT40's.. The intake I have now is an Edelbrock 289 Performer, I'm also wondering if this needs upgrading?
Chad
1990 Notch
12.9 @ 105
Old July 5th, 2009, 07:32 PM   #8
1998 Cobra
13.24@105.66
I wouldn't use either.
I would get better heads (that you can swap onto your new motor later)
and run your stock cam because a custom grind now that you will just toss out later is silly
weeee foooord!
Old July 5th, 2009, 09:51 PM   #9
1990 Notch
Well I wouldn't toss it out, I'm just looking for something that'll work ok with these heads, but then really come alive when I get something better, most likely GT40's. Obviously I'd get better heads if the opportunity arrose, but being a full-time college student on my own making slightly more than minimum wage pretty much shreds that possibility.
Chad
1990 Notch
12.9 @ 105
Old July 6th, 2009, 01:53 PM   #10
1998 Cobra
13.24@105.66
well I understand the college thing totally lol
Right now I'm running a tfs stage 3 cam in my drag car.. and it's really really overkill for my setup, but I'm too poor to change it.
Have you notched your pistons? X cam has a bunch of lift and may interfere
weeee foooord!
Old July 6th, 2009, 10:12 PM   #11
1990 Notch
The shortblock I bought had an X cam in it before, and the pistons were notched out a bit. I'd obviously do the clay mock-up before setting bolting everything together.
So, would I be best of "trading" this cam for something else? If so, can someone point me in the right direction? Someone to talk to?
Chad
1990 Notch
12.9 @ 105
Old July 6th, 2009, 10:20 PM   #12
I wouldn't waste your time with that big of a cam if your stickin with the e7's..
If you want off the shelf then sell it and pickup a used tfs stage1 or e or b cams that are dated but still run decent in stockish motors
but I would suggest on looking at what goals you want to meet with this then build around it
Old July 6th, 2009, 11:42 PM   #13
1990 Notch
I will make a seperate post shortly, asking more about a heads/cam choice, since I don't think I'd get many hits in this thread. Thanks guys!
Chad
1990 Notch
12.9 @ 105
Threads Similar to: Proper valve springs for E7's with an X-cam?
Valve Or Cam Covers THUMPR 2005 - 2010 0 May 11th, 2009 12:05 PM
Valve springs JASonic 99-04 0 February 23rd, 2009 03:19 PM
do i need new valve springs? 00mustang00 99-04 13 October 2nd, 2008 01:56 AM
valve springs flattusmaximus78 5.0 Mustangs 21 March 9th, 2008 10:28 PM
Cam and valve train??? flamed 98 gt 96-98 8 November 2nd, 2007 02:58 PM
