Engine Shut off while driving
I was driving my 89 5.0 last night, and when I stepped on it in 1st gear, the engine shut off when i was at about 4000 rpm. When I tried to start it again, it would fire but not keep running. I had added in cut off switches on the coil and fuel pump but removed them thinking they were the problem. Removing the switches didn't help. After sitting overnight the car will start up again, but when I rev it, it shuts off. I'm stumped. Where should I start looking?
88 LX 5.0 Convertable
Get a gauge and check the fuel pressure.
Robbie_________________ 88 LX Convertible 5.0 84 GT - Project 66 F100 |
Atomized
tfi maybe?
spray and pray |
+1 but first check your fuel filter, make sure it's not clogged. then check ur fuel pressure, and maybe pull out a meter and check to see if u fuel pump died on ya, im not totaly sure if you can check the fuel pump tho cause im not sure if you have to remove the tank to pull it/check it. other than that see what kinda voltage your getting off the lines leading to the pump. i could be wrong cause ive never worked on a fox body's fuel system but it's always worth a shot if it's free.
![]() Silver Vehicle Club Member #2 MM Truck Crew Member #2 MODS LIST: Synthetic blinker fluid, Stg2 muffler bearings(cryo treated), Upgraded bumper bolts, computer reflashIII, 92hp shot of nitrous into the transmission(faster shifting and makes it 24/7 shifting fukkers!), Titanum locking oil drain plug(weight reduction), Spongebob harness(gotta be safe), Oil cooled air intake with a built in turbo simulator blow off valve, and a custom CANOOTER valve! |
thanks, I appreciate the responses. I cannot get the fuel pressure gauge until tomorrow, but I'm gunna check that for sure. I made a small video so you can see what I mean when I say it fires. How would I check the TFI? Try one that from a different car that I know works? Thanks
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://s104.photobucket.com/flash/player.swf?file=http://vid104.photobucket.com/albums/m185/theusualcliche/CIMG1168.flv"></embed>
Alright, so I don't know how to post a video in my response. Here is the link to the video of what I meant when I said it fires but doesn't continue running. Thanks
87GT,AOD,All Stock,3.73s
When it shut off, did it do so without warning? If so, then it maybe TFI module as mentioned earlier or your distributor.
1985 Mustang GT
check the grounds..had one pop off on a friends car and we damn near pulled it all apart...stupid grounds...
I checked my fuel pressure today with a gauge. When it primed before starting I was seeing about 45, the car started for about 30 sec, and I saw about 39-40 at idle. It shut off after about 30 seconds. Im definately thinking its related to the tfi in some way.
Thanks
Well the problem was definately in the distributor, probably the tfi. I put in a known good dizzy and the car fired right up. Is there a way that I could pinpoint the problem to the tfi module and if the tfi is the only problem can I just replace the module and not the entire dizzy? Or would I be better off replacing the whole thing? If so what brand is suggested?
Threads Similar to: Engine Shut off while driving
| Unexpected Engine Shut Down!! Help! | fastang | 2005 - 2010 | 21 | January 4th, 2009 11:51 AM |
| Engine hisses after shut off | Humphry | 2005 - 2010 | 11 | June 9th, 2008 10:10 AM |
| Engine Lagging After Stop-Go Driving | OcOnnor220 | 99-04 | 7 | October 7th, 2007 07:29 PM |
| loss of power//ruff idle and engine shut down.// no start | dj hexadron | 99-04 | 1 | July 25th, 2007 12:41 AM |
| Engine Dies While Driving | Mystic Mama | 96-98 | 7 | May 6th, 2006 07:55 PM |
