Clutch problem
I've had this problem for a long while now the clutch pedal or say something connected to it is causing a lot of rattling when I let completely off the clutch. If I put a little bit of pressure on the pedal it will stop but of course the throwout bearing will start squeeling.
This is the second clutch I've had in the car in less than a year (first one went out cause of a bad throwout bearing that came with it.). Oh and before I forget I switched out the stock quadrant and stuff for a steeda/upr adjustable setup so i have the firewall piece and the 3 hook piece installed. |
You just said what's wrong with it.
weeee foooord!
which is? I mean the only thing that i could get to temporarily fix it was on the stock quadrant u can somewhat adjust it to make it tighter but it wouldnt stay long at all.
get aftermarket quadrent/cable/adjuster/throwout bearing and call it a day
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
actually, just put a t-56 in it
1993 5.ohhhh
12.97 @140mph
If your old throw out bearing took out a clutch, and your new one is rattling, and the same old throwout bearing is making noise. Ehh forget it I'm stumped.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
maybe im being misunderstood the throw bearing was replaced along with the clutch and im not getting the same rattling minus a few other problems that the new clutch solved so to simplify it this is the setup now
new clutch/ bearing adjustable quadrant/firewall cable setup pedal is rattling when my foot is completely off it ..... then if I apply a little bit of pressure the rattle stops but the squeeling from the bearing will start up |
1986 mustang gt
check to make sure is perfectly inline, like the input shaft, pilot bearing, bellhousing. if your throwout bearings keep going out, you have a misalignment somewhere.
1994 GT
a throwout bearing isnt going to destroy a clutch
Cohagan Engineering, Inc. |
Threads Similar to: Clutch problem
| Clutch problem!!!!! | Venomous_Stang | 94-95 | 11 | February 10th, 2009 11:05 AM |
| clutch problem | rainier446 | 99-04 | 1 | December 13th, 2008 10:30 PM |
| clutch problem | gray8188 | 99-04 | 8 | August 2nd, 2008 08:57 PM |
| Clutch Problem? HELP | EasyE64 | V6 Mustangs | 40 | November 27th, 2007 08:45 PM |
| clutch problem | rottikk | 5.0 Mustangs | 6 | November 28th, 2006 09:03 PM |
