AOD Swap Help....
Old July 6th, 2009, 01:37 PM   #1
Stangzilla's Avatar
Stangzilla is on a distinguished road
AOD Swap Help....
I am the proud new owner of a Lentech Strip Terminator AOD... Complete with SFI bell & transbrake... No more clutch!!! WooHooo!! I have been a manual guy my whole life.. Since I have done the 408 build I have been just itching to do the swap.. I knew I wanted to only have to buy one time so I decided to go with the unit that I bought. Now, I think I am gonna go with the Hurst Hammer Style Mustang console shifter unless someone has a good reason not to? I want to maintain the console look but of course not sacrifice the performance that I need. I have the tranny cooler, but I need some help on what else I need. Crossmember? Driveshaft yolk? Anything and everything else? Oh that reminds me I am running a Tremec 3550 now with the BBK ceramic longtubes. Since the Tremec is a much bigger unit in size than the T5 will these headers work with my new AOD? Anything else u freaks can think of that I might need let me know.. Thanks guys...
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old July 6th, 2009, 09:43 PM   #2
86er's Avatar
cross member might have to be moved back, thats just busting the spot welds and moving it.
Drive shaft, that one I am not sure. I know a t5,aod,c4 can use the same driveshaft.
cooler, lines and fittings are all you need to set that up
Just a truck
Old July 6th, 2009, 09:46 PM   #3
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Unless you have a manual valvebody, is there really any performance to be gained or lost by the shifter in an automatic?
O o
/¯/______________________
\_\
Old July 7th, 2009, 01:04 AM   #4
Stangzilla's Avatar
I would have 2 say yes on that. Maybe not on a tranny that is stock or just has a mild shift kit... Have you ever felt how sloppy a stock shifter is? Not 2 mention it not having a trustworthy reverse lockout. I'm sure it cant be good to smack it into reverse while shifting cuz the stock lock breaks..On a fully built tranny the shifts r lightning quick. Sloppy stock shifter, linkage, cable ect mean longer shift times means slower ET.. it all adds up ya know?
Old July 7th, 2009, 01:18 AM   #5
Stangzilla's Avatar
Did some research and the crossmember will work. I just happen 2 hve a brandy-new 1. The bushings r bad in the 1 that is in the car so I just bought a new member. It comes with the outer sleeves not welded so I am good there.. I got the part # 4 the yolk that I need. Its the 28slpine slip yolk. I already ordered the cooler. I need a flexplate & hardware. I need a block plate 4 an automatic that by the way I cant find, a little help here please? I gotta get a dipstick, I think thats it? Unless someone can think of somethin' else?... Thanx...
Old July 7th, 2009, 01:21 AM   #6
87gtmustang's Avatar
1987 mustang GT
87gtmustang is on a distinguished road
Send a message via MSN to 87gtmustang
i love you sig stangzilla did u just make it up
5.0, steeda short shifter, edelbrock intake upper and lower, bbk cold air intake, 3.73, b303 cam, 65 mm throttle body, 65mm mass air, 24 lbs injectors, h pipe, dual flows dump
and more to come
Threads Similar to: AOD Swap Help....
aod to t-5 swap 88stangGT 5.0 Mustangs 17 May 23rd, 2008 09:50 AM
Will h pipe swap between t5 and aod Iwannagofast 5.0 Mustangs 4 February 18th, 2008 03:55 PM
aod swap kratos2250 5.0 Mustangs 1 June 13th, 2007 05:03 AM
T5 to a AOD swap in a 95GT 66879401GTs 94-95 1 April 2nd, 2007 03:24 PM
aod swap to a t5 stang boi 91 5.0 Mustangs 2 March 29th, 2007 11:15 PM
