Discussing second gear help? in the 5.0 Mustangs Forum. Stupid question, I have a freshly rebuilt T-5 w/ all new sinkrows and a ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
second gear help?
1990 LX hatch
what kind of lube ya got in it
Originally Posted by HELLRAZR94 what up pussy lets stop talking shit i would love for your pussy ass to come to cali so that i can show you what im about, when you get here let me know and i will come to you fag
first of all there is a break in period before you start beatin on it. next go ahead and drain your trans and fill it with b&m trick shift atf. this is great lube for your t-5. take it easy on it for awhile
hey chevy boy.....i got something for you to POWERSTROKE! Warning: surgeon general says its ok to smoke ricers! |
lol, never seen anyone spell it like "sinkrows". Not making fun of you, it just looked funny. Anyways, don't run a synthetic fluid. It will end up breaking down the friction material on the stop rings of the synchronizers.
95 Mustang GT Slow Bolt On Car http://img61.imageshack.us/img61/8386/sig4rx2.jpg www.steelcitystangs.com |
Not sure waht kinda lube, i bought it with it all rebuilt, and yea i can't spell for shit, but any ways the trans prolly has about 500-600 miles on it after the rebuild.
do you have an adjustable shifter? check that if u do..
Rotating The Earth 1320 Feet At A Time!! The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.” |
1990 LX hatch
Sounds like the sunk row is on its way out. Some rebuild kits are cheap and come with the brass sincros, there ment for gear lube. The ones with the paper friction material linings are ment for ATF. It could be bent shift forks, or clutch linkage too. On another note synthetic fluid is fine it lasts alot longer too. The shitty thing about the t-5 is that ATF breaks down under relativly low temps, Any time you are hard on the trans, or any time that it gets the fluid over 300 deg., swap out the old fluid. I change it every time I go to the track.
#8 | |
#9 | ||
1990 LX hatch
I know you are not being a smartass, I didn't mean to come off strong like that. Synthetic fluid does meet the standards completely. But do you always want the standard or do you want something better? I work at a transmission shop and they are pretty much the only thing I like doing on cars because everyone is so afraid of it and I understand them. The chemical compounds in synthetic blend oils just end up over time breaking down the fibers of the lining. You don't need to worry aboyt it but if it was my car, sometime in the future I would change to a regular blend oil. But it won't happen immediately and you are absolutely right. The synthetic blend oil meets the standards.
here is a thread with someone also stating it.
http://www.moddedmustangs.com/forums...tml?highlight=
Thanks , I'll prolly change it out when it gets warmer, plus it all happened when I decided to take it out in single digit weather, so that wasn't the smartest thing I coulda done, and I'm debating a shift linkage quadrant cause i have to push my clutch into the floor, probably past it if I could, in order for the clutch to fully engage, so it prolly needs adjustmant
1990 LX hatch
that happened to me once. First thing pull thee pedal twards you, just in case it's the adjuster. Or, FOR NOW you could just put about 1/8" worth of washers between your firewall and the rubber bushing on the cable. Then go get an adj. cable
1990 Mustang LX
9.36@143 mph
Sounds like worn out syncros......common problem.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
Threads Similar to: second gear help?
| 2nd Gear | Lefty10 | Engine | 1 | October 10th, 2007 12:50 AM |
| yes more gear ? | finaly03vert | Modular Mustangs | 12 | September 23rd, 2007 11:48 PM |
| 4.30 Gear to much gear for street use/daily driver? | Bigb2000GT | 99-04 | 10 | March 28th, 2007 05:22 PM |
| which would be a better gear for me? | Torry Jobe | Drivetrain | 33 | March 12th, 2007 07:08 PM |
| 7 tooth drive gear or 8 tooth drive gear for my 98 GT manual | Blue98GT | Modular Mustangs | 1 | January 6th, 2007 07:27 PM |
