#121 |
1993 5.ohhhh
12.97 @140mph
I'm going to put my palm over the radiotor when the airs comming through, because I heard there may not be bubbles. In any case... if it's a head gasket... thats cool and even if it's not, I still have a vibration.
If it is, I'll replace that get it running. Make sure it still runs the same as before (with the vibration) Then I'm going to borrow a buddies balancer to check that.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
#122 |
1993 5.ohhhh
12.97 @140mph
How is it that if a valve wasn't closing all the way that I would hear air leaking out, but when I spin the motor to open the valves I don't hear any air? That makes no sense to me.
#123 |
What you said doesn't make sense to me....
#124 |
1993 5.ohhhh
12.97 @140mph
wasn't, was the wrong word.
"if" The valve was haning open, or stuck open, or there was a bent valve allowing me to lose compression, putting air in the cylinder would leak out of the valve correct? How come when I simpily open the valves, air doesn't rush out? I have a compressor hooked up to the car and it will hold 100psi plus and not leak air out of any orphace.
#125 | |
#126 |
1993 5.ohhhh
12.97 @140mph
So I cannot simpily pull the rockers off and then push air through it? I thought that, that would close both valves and if there was a leak it would push air through.
Please run me through the process, I don't hear air comming through anything. Even through the intake or exhaust if it suppose to.
#127 |
make sure the tool your using doesnt have a check valve, or something, it should be pushing air in the cylinder
#128 |
1993 5.ohhhh
12.97 @140mph
ok well... did a compression test with a differn't tester with a valve stem in it. It came back as 120psi. Put it back together and it runs fine.
Threads Similar to: rockers
| rockers | Silverblitz | V6 Mustangs | 12 | February 2nd, 2009 02:41 PM |
| Rockers | javier351lx | 5.0 Mustangs | 10 | October 8th, 2007 10:21 AM |
| what rockers? | marks87gt | 5.0 Mustangs | 25 | April 10th, 2007 11:52 PM |
| rockers | DragonFreak | 96-98 | 4 | April 4th, 2007 01:11 PM |
| rockers... | Fastpitchdad | 5.0 Mustangs | 2 | November 28th, 2006 09:08 PM |
