rockers
Old July 7th, 2009, 11:48 AM   #1
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
rockers
Just got done with the springs, which wasn't to hard... but sucked none the less. Either way, back to putting the rest back together. I want to intall the rockers 100 percent right this time around.
What is the exact process, and tq specs in doing so?
e7 rockers nothing special, gt40p heads, stock rockers blah blah blah.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old July 7th, 2009, 12:09 PM   #2
Proud American
MustangMatt96GT's Avatar
You got to adjust the rockers on the correct lobe of the cam... Meaning you will have to do the exhiast valves right when the exhaust lifter/pushrod starts to move up. And you do the intake when the intake valve is starting to close... I don't have exact torque specs though.
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old July 7th, 2009, 12:27 PM   #3
Torque and go.....
PeteAndersonRacing.com
Old July 7th, 2009, 12:39 PM   #4
1998 Cobra
13.24@105.66
for some reason 22 ft lbs keep comming to mind. let me triple check that.
weeee foooord!
Old July 7th, 2009, 01:59 PM   #5
1993 5.ohhhh
12.97 @140mph
So mustank, just yeild to spec and then she's good to go?
edit: waiting tripple check.
Old July 7th, 2009, 02:13 PM   #6
Yup stock rockers torque down and go.....
Old July 7th, 2009, 02:14 PM   #7
Proud American
You have to torque them on the right part of the cam though still.
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old July 7th, 2009, 02:18 PM   #8
nope
Old July 7th, 2009, 02:27 PM   #9
1993 5.ohhhh
12.97 @140mph
Sweet. after doing the valvesprings on the car and slapping the rockers and everthing on does it matter were the bottom end since, since the valves were done with the rockers off?
Or can I just put her back togethr and crank it up?
Old July 7th, 2009, 02:31 PM   #10
Dont get what your sayin....
What valve springs did you get?
What was installed height.... What were your measurments for coil bind?
Old July 7th, 2009, 02:42 PM   #11
1993 5.ohhhh
12.97 @140mph
Replacement phead springs... nothing more nothing less. So pretty much the stockers just stronger.
I did the swap with the head on the car. I did the roped trick, compressed the springs and swapped out the springs retainers and locks with the new ones. I followed the firing order. This involved cranking the motor over by hand and I was wondering if it matter were the bottom end was when I go to fire it up for the first time.
Old July 7th, 2009, 02:49 PM   #12
Nothing changed....you didnt remove the cam..didnt remove the distributor..Doesnt matter where the motor is....fire it up
Old July 7th, 2009, 02:54 PM   #13
1993 5.ohhhh
12.97 @140mph
Thats all I want to know buddy. Appreciate it.
I need to go look up the specs on the rockers. I'll get to work on it later... raining out, florida fails.
Old July 7th, 2009, 03:08 PM   #14
Specs are in your arms lol....Thats how i do mine....
Old July 7th, 2009, 03:13 PM   #15
1993 5.ohhhh
12.97 @140mph
nah, can't trust these loaded guns. I'll find a spec and make sure the pushrod can still spin and go from there.
Old July 7th, 2009, 05:29 PM   #16
86er's Avatar
86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold
just bolt them on torque to 22ft lbs and be done with it, ITS THAT SIMPLE NICK lol
Just a truck
Old July 7th, 2009, 05:30 PM   #17
86er's Avatar
how do you adjust a pedestal mounted rocker?????
Just a truck
Old July 7th, 2009, 06:47 PM   #18
Chris951's Avatar
1991 mustang 5.0
Chris951 is on a distinguished road
pedestal mount rockers are 18-20lb's I'm pretty sure
Old July 7th, 2009, 07:51 PM   #19
1993 5.ohhhh
12.97 @140mph
I cranked them all to 22 ftlbs then a couple notces more for safe keeping. Should they have a SMALL it of movement from side to side over the valve? and I meen small. Like a nut hair?
Old July 7th, 2009, 08:59 PM   #20
Side to side is fine
Threads Similar to: rockers
rockers Silverblitz V6 Mustangs 12 February 2nd, 2009 03:41 PM
Rockers javier351lx 5.0 Mustangs 10 October 8th, 2007 11:21 AM
what rockers? marks87gt 5.0 Mustangs 25 April 11th, 2007 12:52 AM
rockers DragonFreak 96-98 4 April 4th, 2007 02:11 PM
rockers... Fastpitchdad 5.0 Mustangs 2 November 28th, 2006 10:08 PM
