Removing the EGR valve
Old July 7th, 2009, 09:57 PM   #1
1989 Mustang LX Saleen
orangesaleen89 is on a distinguished road
Question
I want to remove the egr valve do I have to plug the vacume line and what do I do with the plug?
Old July 7th, 2009, 11:14 PM   #2
egr valve... the vac line that runs from it to the round plastic thing on the pas side shock tower is the egr solenoid which you won't need if your disabling the egr system so yank it as well.
Old July 8th, 2009, 01:48 PM   #3
EscortSportage's Avatar
1989 Mustang GT 5.0
whats the point on removing the egr stuff?
http://www.tumblr.com/blog/escortsportage
Maximum Motorsports Catelog
A.Senna
Old July 8th, 2009, 02:04 PM   #4
kilby91's Avatar
1991 Mustang GT
kilby91 is on a distinguished road
You gonna remove just the egr valve or are you gonna delete the egr spacer between the TB and Plenum? You can get a cover that will use the existing bolt holes and fill the gap so you don't have a vacuum leak.. You could just leave it on the car and unplug the vacuum to the egr valve so that it will not open.. It won't trigger your check engine light to come on, but will show code 33 in a diagnostic test..
Old July 8th, 2009, 07:29 PM   #5
ryans88gt's Avatar
ryans88gt is a jewel in the roughryans88gt is a jewel in the roughryans88gt is a jewel in the rough
get an EGR simulator and EGR delete plate. Looks much better.
FORD MUSTANG 87 88 89 90 EGR SPACER DELETE PLATE 90MM:eBay Motors (item 110410237502 end time Jul-13-09 03:33:44 PDT)
EGR ELIMINATOR SIMULATOR 1987-95 FORD MUSTANG 5.0:eBay Motors (item 300327326790 end time Jul-09-09 16:09:13 PDT)
Then remove the EGR junk and solenoid crap and 6 way plastic vacuum connector garbage.
Old July 8th, 2009, 07:52 PM   #6
onederful100's Avatar
2007 GT 2000 GT
onederful100 has a spectacular aura aboutonederful100 has a spectacular aura aboutonederful100 has a spectacular aura about
do you need that delete plate or could you just do the egr simulator?
http://i243.photobucket.com/albums/ff26/onederful100/avatars/sig-52.gif
2007 GT 5spd
2000 GT 5spd
whipple crew member
2-Stang Crew
My Car
Old July 8th, 2009, 08:01 PM   #7
ryans88gt's Avatar
If you don't get the plate, then you have to leave the spacer on there, which kind of makes the delete pointless.
Old July 8th, 2009, 08:24 PM   #8
1986 mustang gt
1fst5.0 is on a distinguished road
i have the spacer and simulator. should i also remove all those solenoids and vaccum hoses on the shock tower too?
Threads Similar to: Removing the EGR valve
Will a Egr valve..... vinniepearl 94-95 1 June 16th, 2008 04:23 PM
Egr Valve Help!! 01sta1k3r 99-04 2 April 9th, 2008 10:08 PM
Egr Valve And Pcv Valve Delete? Jeffery9508 V6 Mustangs 16 January 28th, 2008 09:45 PM
EGR Valve sorrowfulkiller 96-98 13 September 11th, 2007 11:35 PM
new egr valve mikethetigerrr V6 Mustangs 9 April 29th, 2007 02:12 PM
