weird idle
Old July 9th, 2009, 08:06 AM   #1
fordrangerguy is on a distinguished road
weird idle
ok im back again with my neighbors 1991 foxbody 5.0 now the problem we are having is that he cut off some of his exhaust pipes after the muffler and now the car idles funny like it will stay near 1K rpm but will drop to about 850 rpm and comeback up again and its a bit rough could the pipes that he cut off have made that big of a difference when i say it was not much pipe he didnt like how it looked it bent over the axle and dumped on tghe other side of the axle what do yall think it could be from
Old July 9th, 2009, 03:21 PM   #2
angermgt's Avatar
angermgt is on a distinguished road
do the idle reset found at the top of forum page. that should work.
490whp/432wtq, V2 13lbs. boost, 3.33 pulley
Old July 9th, 2009, 04:16 PM   #3
thanks man we will give that a try tonite its just weird i mean today it wasnt as bad as it was lastnite and it ran smoother today its weird how this car is
Old July 9th, 2009, 04:21 PM   #4
kilby91's Avatar
1991 Mustang GT
kilby91 is on a distinguished road
Cutting the pipe off after the muffler should not affect anything to do with driveability..
These cars will make you pull your hair out when they have intermittent idle issues...
Old July 9th, 2009, 09:25 PM   #5
nolife's Avatar
91GT, 88GT, 02GT
Like others said, it has nothing to do with the idle. As a side note, I'd put some turn downs on. The exhaust will heat up the gas tank, mine did it enough to cause a plume of hot fumes to come out of the filler when I opened it to put gas in. You can make some decent turndowns with a small curved piece of tail pipe you cut off.
Old July 9th, 2009, 09:48 PM   #6
aka Nature boy
sickfox's Avatar
blk 89/red 91 XJ Limited
I like turtles
sickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant future
i have 3 grey ones dont know what "year" but one is in my 89
Black Stang Crew Founder #-1
MM+Cleavage Club #15
www.xjor.org
I would drag my dick through a mile of broken glass just to hear her fart through a walkie talkie
Threads Similar to: weird idle
weird idle. energiesource 99-04 9 June 1st, 2009 08:21 PM
umm have a weird problem? idle problem? blue03mach1 99-04 16 March 4th, 2008 12:03 PM
97 cobra idle weird jys97svtcobra Modular Mustangs 2 February 25th, 2007 10:51 AM
Weird Idle problem geolebon 99-04 17 February 17th, 2007 09:10 PM
Idle Problems Code 1506, Idle Overspeed Error jagstang96 96-98 3 August 29th, 2006 04:11 AM
