Turbo Car Burning Alot of Oil
Old July 10th, 2009, 07:14 AM   #1
RaceRelated's Avatar
RaceRelated is on a distinguished road
Exclamation
I dont understand why but sometimes when I start the car ill get a puff of blue smoke. Or if I get into boost while accelerating i can see a cloud behind me? I changed my oil about 3 weeks ago topped it off, and now its reading in the add mark? any ideas? what I can look at? the car is running real fat if that has anything to do with it? thanks guys
Old July 10th, 2009, 07:22 AM   #2
also i do have alot of blow by on the oil fill breather... and i thought i saw some oil in the back of the lower intake but i was not sure exact it was dark and i was at work, but it may have been some water coming in through the cowl. (FL WET WEATHER) anything will help thanks again
Old July 10th, 2009, 07:24 AM   #3
Arctic Fox's Avatar
1989 GT
KB 2.1L Flowzilla
Arctic Fox will become famous soon enough
How is the PCV system setup, not stock i hope?
Old July 10th, 2009, 07:40 AM   #4
its just vented out nothing back into the intake
Old July 10th, 2009, 08:42 AM   #5
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
Sounds like you need to start running a catch can.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old July 10th, 2009, 09:39 AM   #6
that just circulates the oil back into the pan right? instead of it blowing i guess out of the engine???
Old July 10th, 2009, 10:10 AM   #7
nolife's Avatar
91GT, 88GT, 02GT
How about the line from the valve cover tube to the throttle body? Is that disconnected and capped off as well and a breather instead of the cap on that filler neck?
If so.. sounds like it might be time for some cylinder work. Have you done a compression test lately or have some numbers to compare to?
Old July 10th, 2009, 11:06 AM   #8
no tests lately, but the nipple off the throttle body is capped off, there is a breather on the filler neck, and the pvc is vented into the atmospere. cylinder work?!?!?!?!
Old July 10th, 2009, 11:08 AM   #9
1993 5.ohhhh
12.97 @140mph
Can't you still get blow by thought? Mines capped off and vented, no breather tough. I need one asap. I still get some oil in the pipes, but no smoke out the back.
Anyone ever use a one way check valve?
Old July 10th, 2009, 11:40 AM   #10
Im getting blue smoke though, so maybe its time for a tear down...or go till it blows
Old July 10th, 2009, 12:17 PM   #11
1985 Mustang GT
viperlocc is on a distinguished road
i'd say your turbo is going....oil seals
Old July 10th, 2009, 12:36 PM   #12
1993 5.ohhhh
12.97 @140mph
Ahh didn't even think about that.
Old July 10th, 2009, 12:44 PM   #13
1985 Mustang GT
take your intake off the turbo and you just might see oil in their. if not, check the exhaust side.
it'll either be a very small amount of oil/oil residue or a lot. doesnt take much oil to make a lot of smoke
Old July 10th, 2009, 01:27 PM   #14
1993 5.ohhhh
12.97 @140mph
You could have oil in the turbo if your getting blow by though. correct or not correct?
Old July 10th, 2009, 01:40 PM   #15
id say your correct, but im not pouring smoke or nothing just a puff when i wack it, but that is one of my first todos, is im gonna check the exhaust side first. I know its not in the cylinders cause if it was a ring it would smoke out and in the throttle, but its not anything major at all. but it could be a beginning of seals going.
Old July 10th, 2009, 01:43 PM   #16
wouldnt there be more oil in the exhaust side than the intake side if it was seals?
Old July 10th, 2009, 01:50 PM   #17
1985 Mustang GT
not necessarily . take off the intake cause it'll show you if oil is coming in through the pvc. check the pvc, if thats oiled, then get a catch can. if its dry, then check the exhaust side.
if that all checks out, then start pulling plugs to see if its internal. but i'd say its turbo/pvc system.
does it make any weird noises when you start boosting? anything that you havnt noticed before? do you loose pressure after you hit max psi when boosting?
Old July 10th, 2009, 01:56 PM   #18
no it spikes and holds and the only noise you hear is spool and 50mm of tial wastegate screaming!!
Old July 10th, 2009, 01:59 PM   #19
i think its in the pcv system too turbo is fairly new i cant imagine seals going already for one, i dont beat my car so i think your on to something.
ill check intake side first
Old July 10th, 2009, 02:35 PM   #20
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Turbo seals or inadequate crankcase ventilation system are the most probable causes.
+1 very possible
Doesn't matter if it is fairly new, it could still have bad seals for a variety of reasons.
Threads Similar to: Turbo Car Burning Alot of Oil
oil burning ?'s 93lx306dev 5.0 Mustangs 1 April 4th, 2009 11:03 PM
Burning oil 69fastback Classic Mustangs 6 February 15th, 2009 11:46 AM
Am I Burning Oil? PiggySmallz 2005 - 2010 55 December 28th, 2008 10:52 AM
burning oil??????? 5LBennett 5.0 Mustangs 20 July 4th, 2007 12:34 PM
Burning Oil terribleonexx88 5.0 Mustangs 11 November 13th, 2006 11:45 PM
