vent on valve cover
Old February 1st, 2007, 12:52 PM   #1
cdunc24's Avatar
cdunc24 is on a distinguished road
vent on valve cover
Does the valve cover vent go to anything? mine had just a cut off piece of hose when i bought it.
"It's the fastest who gets paid...
and it's the fastest who gets laid"
- Reece Bobby
Old February 1st, 2007, 01:50 PM   #2
terribleonexx88's Avatar
terribleonexx88 is on a distinguished road
Send a message via AIM to terribleonexx88
is it on the oil filler neck?
85 svo. work in progress
Old February 1st, 2007, 04:42 PM   #3
TurboLX's Avatar
1988 Mustang LX Turbo
your supposed to put a re-breather on it and it was problably hooked to the upper intake
Old February 1st, 2007, 07:29 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
It connects to the throttle body.
Old February 2nd, 2007, 02:24 PM   #5
cdunc24's Avatar
yes it is on the oil filler neck. in have att, a pic. it is above the right side of the alternator.
where on the t-body?
i do have a rubber hose that runs under the upper intake plenum. i am not sure where it goes. in the picture, it sits right in the middle directly under the intake. it currently has a bolt capping it off (head of bolt is yellow). hopefully this will help you all assist me.
thanks
- Reece Bobby
Old February 2nd, 2007, 02:31 PM   #6
what aftermarket t/b is that
Old February 2nd, 2007, 09:54 PM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Well, maybe I'm wrong. I thought we were talking pre 94. I'm not really sure on 94 and 95 but 87-93 it did connect to the throttle body so there would be negative pressure on the crank case at wide open throttle.
Old February 2nd, 2007, 11:04 PM   #8
JBIGBOOTSY's Avatar
1990 LX hatch
ur gonna have to put it somewhere in the intake tube, before the throttle body.
Old February 3rd, 2007, 09:19 AM   #9
cdunc24's Avatar
i'm sorry, it is a 95, 5.0.
i'm not sure of the brand on the t-body, i can't recall if it even says. it was on when i bought it. i dont even know the size.
- Reece Bobby
Threads Similar to: vent on valve cover
BBK Valve Cover Gasket Hotrodvdog 99-04 20 December 24th, 2007 05:09 PM
Valve cover options caintcatchmyGT 96-98 21 October 24th, 2007 06:20 PM
Valve cover filter? energiesource 99-04 10 July 27th, 2007 01:59 AM
valve cover gasket terribleonexx88 5.0 Mustangs 5 July 25th, 2007 03:20 PM
89 LX pinging from valve cover Steves LX 5.0 Mustangs 3 January 3rd, 2007 10:57 PM
