steeda tri-ax shifter
I'm peicing together a t5 swap kit and I need to know if the steeda tri-ax shifters come with the handle.
it does, disregard this post.
87 Mustang GT T-top
( From their Web site )
Benefits * "Offset-Preload" coil springs find third gear for you - so you won't miss! * Most comfortable hand position of any short throw shifter * Two position adjustable height * Shortest throw of any shifter * Smooth, confident, precise shifts * Exclusive BootGuard (prevents damage to factory rubber inner boot) * Adjustable positive stops prevent over extending the shift lever, preventing costly transmission damage * Compact tower design is easier to install * CNC machined from billet 6061 T-6 aluminum * Heavy duty construction. No welds, stampings, or castings to break * Nickel plated pivot shaft won't rust or stain * Grade 8 and stainless steel hardware * Made in the USA * Accepts factory & Steeda knobs * Includes Steeda's exclusive Tri-Ax shift handle * No complicated, unnecessary adjustments unlike competitive design If you are talking about the Shift Knot, probably not. i am 90% sure it doesnt come with it, but there is still that 10%. You would have to use your own ( stock ) one. |
Moderator
It comes with the handle, but not a knob. I used a stock one on my Tri-Ax.
There's a reason Ford codenamed them the Terminator
1988 Mustang 5.0 LX
12.48@118.27
my girlfriend bought mine it came with the shifter knob and a forged aluminum shifter arm
Threads Similar to: steeda tri-ax shifter
| steeda tri shifter...any help? | blue03mach1 | 99-04 | 7 | December 25th, 2008 03:08 PM |
| Steeda Tri-ax shifter | fastford3388 | 5.0 Mustangs | 4 | May 7th, 2008 01:45 PM |
