Shifter & Trans Cooler..
I just got my shifter & trans cooler 4 my Lentech AOD. I went with the B&M Pro-Stick with the magnum grip & wow this thing is awesome!! Cant wait to bang gears like a mofo with this thing!!
The tranny cooler I want all you guys that run a modified or fully built automatic like myself. This thig is sooo worth the $100 + shipping=$114.99.. Dual pass copper&brass with a Spal fan.. Check it out if u r in the market 4 1...Universal Parts, Inc. B&M Magnum Grip Pro Stick shifter 81040
I just bought one from a junk yard off a mid to late eighties f150 with the tow package, pressure tested it in my tub, cleaned it and painted it black.
Its nice and big with 1/2 npt openings on it.
Just a truck 5.4 3v: 264hp 317ft lbs rock stock piecing together the next project faster than your first sexual experience |
I know u can get them from a junk yard, I just wanted 2 show people that its not alot of $$ for a superior unit. Its not often that u find something really nice 4 a good price.. I just spent $4550 on a Lentech Strip Terminator AOD & I did not want 2 use a junkyard cooler on it.. Good luck with yours though it should work fine with what u have...
if im reading this wrong forgive me, but ill gladly take my junk yard coolered car and stripe your lentech
#5 | |
U r reading it wrong!! Why did u not ask 4 clarification b4 u talk smack about "striping" my car then askin 4 forgivness if u read it wrong. Jeez Whatever...
with out knowing my set up, this is a very dick sounding line
aka Nature boy
blk 89/red 91 XJ Limited
I like turtles
anyways, glad you found a great piece, and those shifters are nice, def a good spend on b&m
#9 | |
I would love 2 take u up on that as u call it "stripe" my ride... only prob is that u live where u live and the same goes 4 me? Hmmmm we will have 2 think of something......
hey i want to get a b&m shifter for my aod too. when i do, can i shift through all the gears or does 2 and 3 still share???
Well my Strip Terminator AOD besides being fully built it has a manual valve body which if u don't know I have 2 shift through the gears. There is no just put it in drive on mine. Now as far as what u r talkin about & someone correct me if I'm wrong cuz I'm not fully up 2 speed on automatics this is my first 1. It's my understanding that your tranny I'm guessing is pretty much stock shares the 2-3 gears on the D..? That I think is due 2 the way the valve body is designed & as the engine revs the pressure in the tranny increases causing the upshift. My setup because it's a racing trans is designed so the line pressure is fixed along with the manual valvebody I have 2 manually shift mine. So what I'm thinkin is that u will need a different VB in order 2 do what u want. I don't think just a shifter will achieve that.. He'll while your puttin in the valve body might as well freshin the thing up also put in a shift kit & converter ect.. I don't know how much power u r makin but just like any stock or mostly stock tranny might not live 2 long with just a VB, converter, shift kit.. But hey ya never know..!!!
thanks thats what i thought i would have to do. I just had my tranny fully rebuilt with shift kit and upgraded stall, so ill just wait till i build my 331 and throw a manual VB in it.
Threads Similar to: Shifter & Trans Cooler..
| best trans oil cooler | unblock | 99-04 | 3 | December 3rd, 2008 07:49 PM |
| trans cooler question | bretts95gt | 94-95 | 0 | September 25th, 2008 02:56 AM |
| Trans cooler?? | Shibby50 | 99-04 | 2 | July 25th, 2008 05:17 AM |
| Trans. Cooler | chris1 | 4V / SVT | 8 | June 25th, 2008 11:56 PM |
| Trans Kit and Cooler and Exhaust? | willsurforbeer9 | V6 Mustangs | 5 | December 23rd, 2007 09:17 PM |
