93 GT
95 not running right
has anyone had a problem with the computer going bad causing it not to run right? Its the only thing we can think of thats wrong with it
we put in a new msd distributor and coil pack, so we figured it might be timing but we've checked it several times and it about spot on. What the car does at idle is it will start up and idle fine for a few seconds then it will start to flutter up and down from under 1k. when you drive it it seems lagged, and wants to stall when coming to a stop. would a bad computer cause this? |
#2 | |
Skirt Chasing Philanderer
Kit Car/Ducati/Explorer
Nike Fast
Have you tried using some eye solution and cleaning the mass air meter? I know this was a big issue with a friends, he had to do this about once every couple months. I bet this solves your problems...
Might want to consider writing down what is said above, it will help you at some point or another in your life!
1986 mustang gt
u scan for codes?
93 GT
It started before the distributor, but it would idle at a higher rpm but now its doing it at a lower but it still wanted to cut out and lag...I'm from jacksonville. Were about to go try the eye wash hopefully its that simply
93 GT
Ya it read error, we put in a new radiator and it seems like it gets blistering hot along with the distributor
1986 mustang gt
what was the code?
Nike Fast
93 GT
not sure i wasnt there when he had it read, all he told me was error were gonna take it to have it read again today
Threads Similar to: 95 not running right
| Got Her Running, But wont stay running...help? | Speedstang302 | 5.0 Mustangs | 10 | August 28th, 2011 06:58 PM |
| Running like S**T | 347stroker | 99-04 | 18 | March 16th, 2009 05:02 PM |
| Anyone running these? | SDYC00GT | 99-04 | 20 | March 2nd, 2009 03:43 PM |
| got it running again | e3sean | 5.0 Mustangs | 27 | June 20th, 2008 03:51 AM |
| running a little better | e3sean | 5.0 Mustangs | 7 | March 23rd, 2008 05:10 AM |
